KARAOKE SCENE MAGAZINE ONLINE! - Mackie 1604 VLZ Pro Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Fri Nov 06, 2026 6:29 pm
 Post subject: Mackie 1604 VLZ Pro
PostPosted: Mon Jan 28, 2008 11:02 pm
Non-Member
Using 2 amps, right and left mains are going into the tops (#1 amp)
the subs are being fed by the Main mix mono out.(#2 amp)   There is no way to control the bass volume.   Any idea which control will adjust the bass volume?  I know about the mono volume knob beside the mono jack, but is there a knob on the face of the mixer that will do anything to the bass only.    It needs to be louder than it is now.
The recommendation was the Aux Sends Master, but totally up or totally down makes no difference.
 Post subject: Re: Mackie 1604 VLZ Pro
PostPosted: Tue Jan 29, 2008 1:57 am
Best bet would be to get an external crossover.  Main out to the crossover, the highs to the top speakers (amp combo), lows to the sub.
PostPosted: Tue Jan 29, 2008 4:30 pm
Non-Member
Found the problem.  The reverb was already in AUX #1.  The Aux #2 does the sub volume.
PostPosted: Thu Jan 31, 2008 11:50 am
get an external xover you will not regret it. you will have much more controll over what frequency you actually cross over at and the volume on each amp.
PostPosted: Thu Jan 31, 2008 11:59 am
Exactly!
PostPosted: Thu Jan 31, 2008 12:15 pm
Been Liked: 54 times
Agreed. When I go for my subs, I will definitely buy a crossover with it. Since I probably go with EV subs and own EV tops I might go with the new EV crossover coming out in February, which has pre-settings for all of their speakers.
PostPosted: Thu Jan 31, 2008 1:01 pm
Another great choice is the dbx 223XL or if you want to get fancier, go with their Driverack PA.  Even though they have setting more geared for JBL/Crown combos, with the built in pink noise generator, RTA, and auto eq, you can get any system tuned to the romm it's in, plus store the presets for each room.
Users browsing this forum: No registered users and 2313 guests
