KARAOKE SCENE MAGAZINE ONLINE! - Help with rca plugs Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Fri Nov 06, 2026 8:49 pm
 Post subject: Help with rca plugs
PostPosted: Sat Jan 26, 2008 8:03 am
[align=center][/align][font=Courier][/font]I have two players that I use at the same time. What I do is come out of the back of each player with a yellow rca video cable into an av switch and just switch channels when I switch players to show the lyrics on 1 single T.V.. What I want to do is use the same setup but run 2 TV`s at the sametime. Is there a rca cable that I can plug into the AV box and run into both TV`s? Any help would be appreciated.
Gator
 Post subject: Re: Help with rca plugs
PostPosted: Sat Jan 26, 2008 8:32 am
You could try a simple y splitter but there might be some degradation to the picture quality, otherwise, although a little pricey, this would work for you.
http://www.cablestogo.com/product.asp?c ... ylCjCSvixx
And there might be some other options available as well...maybe someone else will post them.
You should be able to split the signal after it leaves the switch. I use a small rca plug spliter from Radio Shack to send to a second tv.
Jim-n-TN
PostPosted: Sat Jan 26, 2008 8:39 am
link
PostPosted: Sun Jan 27, 2008 7:00 pm
$6.00 splitter after the a/v switch worked perfectly. Thanks for the info..
Gator
PostPosted: Sun Jan 27, 2008 7:29 pm
Glad it worked for you. thanks for letting us know.
Jim-n-TN
PostPosted: Mon Jan 28, 2008 2:30 pm
Yes a Y splitter is the way to go...that's what I have been using and actually both TV's looked great!!!!
Image Image
Users browsing this forum: No registered users and 3128 guests
