KARAOKE SCENE MAGAZINE ONLINE! - need help bad please got a karaoke system in need Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Fri Oct 23, 2026 12:21 am
PostPosted: Fri Dec 19, 2003 9:59 am
what i got is a jvc tripple player,a mackie fr m1400i amp, and a gemini ps727 mixer,the problem is the gemini mixer has only one mic in put so i used a yamaha mixer to combine the mics and run the output from rec out to the line input on the gemini,the jvc is on another line and my cd is on a line i have great music sound but cant get mics to sound just right not enough volume any help in this matter will be greatly appericated .LONG LIVE THE NEW KARAOKE BECAUSE NEW PEOPLE IS WHAT KEEPS KARAOKE GOING .thanks
PostPosted: Fri Dec 19, 2003 12:43 pm
Your problems seems to be your mixer. If I am not mistaken this is a DJ mixer. You need to upgrade to a mixer which has more microphone inputs and effects. Also using the rec out to line in is not helping the sound and is probably the reason for the low level of your mics. What kind of mixer is the Yamaha? I am assuming that it cannot mix the music with mics.
Good Luck
PostPosted: Fri Dec 19, 2003 4:53 pm
According to the specs the mixer has 2 microphone inputs and six line inputs. However, I do not know how much you will be able to tune in the sound on your mics with this mixer. I can't tell if it has tone controls for both mics (I doubt it) and does not seem to have an effects processor.
PostPosted: Sat Dec 20, 2003 12:31 am
there are ALL kinds of better mixers than that one... good call on getting the person steered into the right direction.
i like mackie mixers myself, and after being at lonman's show, I can tell you he really makes it happen with his! My mixer's a bit inferior to his, but I don't play the huge hall he does!
Look around... do a search on Mixers, and ask around what ones the people would recommend.
Matt
PostPosted: Mon Dec 22, 2003 2:06 am
I use a Mackie 1202VLZ Pro on one of my systems.
Great little mixer, but...
It's not the simplest, and you will be paying for a lot of features that you won't use. If I'm not mistaken they run just under $400. The led level set indicator is SO convienant. It makes adjusting the mic and music levels so easy that you can do it from around the block.
If you would like something a little more straight forward and a little less expensive look at the Alesis Multimix 8FX.
To find this mixer shearch for product #630157.
The 8FX has a led level set indicater and EFX.
It has 4 XLR mic inputs and 2 stereo inputs.
Cost-$150.
Kojak
PostPosted: Tue Dec 23, 2003 8:18 pm
no slider knobs... but looks like a very sturdy unit!
Users browsing this forum: No registered users and 2040 guests
