KARAOKE SCENE MAGAZINE ONLINE! - what do I do with zip files? Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Fri Nov 06, 2026 6:47 pm
PostPosted: Wed Jan 16, 2008 8:29 am
Hello,
Im new to the scene.
I downloaded some zip Karaoke files,I tried converting them with MP3+GToolz4.0.1.0
nothing happen no .bin file.
then I extracted the files and got mp3 file and a cdg file,what can I do with them?can I burn them that way.I have Nero 6 and Cdrwin.
Im not a pro
Im just a Dad with a new Singing Machine.
Please help me and take me to school.
Elwood
PostPosted: Wed Jan 16, 2008 8:41 am
Now that you have the MP3 and CDG files, go back to Toolz and select convert MP3G to BIN. You'll have to direct the software to the location of the files.
Toolz doesn't recognize zipped files they must be unzipped.
The go to CDRWin and burn BIN file to disk.
Your burner must be able to recognize CD+G BIN files.
(CDRWin has a tick for CDG, if it lets you select, your drive will do it, if it is grayed out, your drive is not compatible)
PostPosted: Wed Jan 16, 2008 8:55 am
Elwood,
Being that your using that method......
Ensure that (dotnet) Framework is installed prior to installing mp3toolz.
Make sure the cdg and mp3 files are Exactly the same. Except for the extentions.
Example: If one file has an Extra Space... It Won't Work!!!
Re-Zip to Bin (with MP3 Toolz) and burn using nero. VERY SLOW!
NOTE: Your Drive Must Read and Write CDG. Look at Jian's Post
Kind Regards,
sw00000p
PostPosted: Wed Jan 16, 2008 9:03 am
[quote="Dennisgb @ Wed Jan 16, 2008 8:41 am"]
OOpps!! You Sure About That?
I Convert Zip files with mp3toolz All The Time!
Kind Regards,
sw00000p
PostPosted: Wed Jan 16, 2008 9:54 am
Thanks for the repiles
I think my MP3toolz is not working right.it opens up but it says it finds no files in the zip.
is there a better program I should use?to make bin files?
can I burn the mp3 and cdg with Nero? what kind of format do I burn?
thanks again for your help
Elwood
PostPosted: Wed Jan 16, 2008 10:07 am
Been Liked: 15 times
You can go directly from a file on a Karaoke CD to a .bin file using audiograbber. I don't know if that helps?
PostPosted: Wed Jan 16, 2008 1:53 pm
Been Liked: 8 times
Or you can try Power CD+G Burner and burn ZIP files directly to the disc.
PostPosted: Wed Jan 16, 2008 2:05 pm
Elwood
that happens if you don't have the updated mp3toolz or you have a zip file that's higher than mp3toolz recognizes.
Try unzipping them and THEN do the mp3toolz conversion in another folder.
PostPosted: Wed Jan 16, 2008 2:59 pm
+1, This is the easier route.
But even easier still: is to play the file IN your pc. Buy the cable to connect the pc to your all-in one karaoke set.
PostPosted: Wed Jan 16, 2008 4:23 pm
Elwood
You unzip the file and toolZ doesn't recognize it? Do you have an MP3 file and a CDG file? If you do, are they named exactly the same? Are you directing toolZ to the folder you put the file in? They won't show up in the toolz window, until you select convert to BIN. toolz does not recognize all zip files, and there are hundreds of zippers out there.
PostPosted: Wed Jan 16, 2008 8:04 pm
Dennisgb,
Now That make scense!
Elwood,
If you don't want to spend any more money:
MP3 Toolz won't open any file Directly. Whether zipped or not, the files Must
be inside a folder. Right Click on the folder and select mp3 toolz and choose
your effect. If you have the Latest MP3 Toolz, you Can burn a disc with it.
My advice is to use Power CDG Burner! Keep it simple.
Kind Regards,
sw0000p
PostPosted: Mon Jan 21, 2008 4:41 am
Thanks for all your help,
I got my toolz working, my files needed to be in a folder.
then I burned with cdwin.my cd burner burn didn't work in my singing machine,but my dvd burner burns did.
Im on my way
thanks again
Elwood
PostPosted: Tue Jan 22, 2008 11:33 am
I got Power CD+G
its working sofar
How do you make a playlist?
I need to know what is on the disc I make
Is there a way inside Power CD+G?
like Nero
thanks
Elwood
PostPosted: Tue Jan 22, 2008 11:58 am
Been Liked: 8 times
There is 'Print Label' button on Burn tab that allows you to print CD inlays.
Users browsing this forum: No registered users and 2836 guests
