KARAOKE SCENE MAGAZINE ONLINE! - Need Help Burning Bin Files Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Fri Oct 23, 2026 12:20 am
PostPosted: Thu Dec 18, 2003 10:18 pm
Here is what i do"please help me figure this out"
Convert mp3 and .cdg to .bin
By Choosing Zip To Bin
It Creates a .cue file for burning with CDRWin
I Play MP3+G files from the bin file in WinAmp 2.x "Of my Hard drive "
but when i burn in cdr-win with my plextor drive thats supported to burn cd&g i olny get the music no words and in cdr-wn vers 3.9e i goto record now then load tracks i choose cd&g and then load tracks and then i choose bufer underrun and start to burn burns fine but no cd&g i tryed another pc with a differant drive that burns cd&g and bam...." you got it same thing" just hear the music no graphics, I installed the net frame work 1.1 and i'm using MP3G Toolz version 3.0 to convert is there another program i may use is there options thing is before i formatted the 1 pc the lg drive worked with no issues i'm lost i done made 12 coasters with just music
PostPosted: Fri Dec 19, 2003 7:07 am
Did you try to play the discs on a standalone player or just your pc? The discs should work on a CD+G player. In order to play them on your PC, you may need to install another one of the Karaoke player programs. Also did you install the karaoke plugin for winamp? Just guessing. I only use the pc to make custom discs. I have never tried to actually use it as a player.
PostPosted: Fri Dec 19, 2003 8:58 am
I did that one time, and I forgot to check cd+g on the que sheet, and all i got was the music. could this be the problem?
I found that cdrwin will burn just about anything and make a cdg out of it if you check the right boxes. Heck I copied from a cdg with microstudio (it makes a .cdg file) and burned it to a cd with cdrwin, and it worked fine. but microstudio will also play the cd+g disk.
Users browsing this forum: No registered users and 2039 guests
