KARAOKE SCENE MAGAZINE ONLINE! - CD Sleeves Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Fri Nov 06, 2026 9:00 pm
 Post subject: CD Sleeves
PostPosted: Thu Dec 20, 2007 4:12 pm
Hello All,
I am starting my karaoke hosting business and have all of the CD+G's and an Odyssey CD Case, but I need to get CD Sleeves to hold the CD's without scratching them, and also fit in my case.  The goal is to protect the cd's, have an option to label the sleeve (Could be something like an adhesive p-touch label), fit in my Odyssey case and be easy to use.
I found some sleeves at the local dj store (They are similar to the ones here:  http://www.pssl.com/Prosound-Prosleeve-Vinyl-CD-Sleeves---25-Pack) But I wonder how easy they are going to be to use.  The sleeve has protective fabric on the inside but it's not so easy to get the cd in.  I think it would be easier to use if the protective fabric was connected to the outer plastic, then there would only be one opening.  I believe they are made like that to hold the cd artwork.
Any recommendations?
I found a site:  http://www.mmdesign.com/cd-storage-sleeves.htm
They have a bunch of options and are going to send me some samples.
CompUSA had the following:
http://www.compusa.com/products/product ... ode=283642
I know it probably seems a little overboard talking about sleeves, but I figure if I get this right it will make it easier.
Thanks!!
Tim
 Post subject: Re: CD Sleeves
PostPosted: Thu Dec 20, 2007 4:24 pm
I have yet to find anything other than a jewel case that didn't eventually end up scratching a disc, sometimes on the label side which is death to the disc.  All that has to happen is a tiny foreign particle manipulate it's way into the sleeve.
I know it's a space saver, but not the best.  if at all possible go with the slimline jewel cases, they will fit 2 jewel cases in the spot where 1 would normally fit.  So if your cd case would hold 250 jewel cases, it will now hold 500 in the slim case.  How many discs do you have to store?
http://www.cdrrack.com/slimjc-3.html
I have tried virtually every storage out there & the only one I have found not to do any damage is it's own jewelcase, they are bulkier & heavier, but how much is your investment worth to protect?
PostPosted: Thu Dec 20, 2007 5:29 pm
After fighting vinyls for decades I was surprised at a couple of Pioneer jukebox seminars. Cd's were a godsend their lifetime should be 10 times that of vinyl. But the Pioneer engineers applied the same principles to preserving cd's as the old vinyls. In the old jukeboxes from day one the records were in a rack in a vertical position  so dust and crap wouldnt collect on the top surface. I  have seen KJ's carefully not touch but lay a cd on the table with the "playing" side up where falling particles can collect NO. It is better to lay it down on a clean surface..Label up.
Cd's come in a ream stacked in 100's and as long as they are not spun against each other no problem.. Same with a vinyl never allow contact with a rough surface or particles (needle) and sand the surface. (You can play an old mono with a stereo needle but cant play a stereo vinyl with a bigger mono needle) LMAO
With the old tuber jukes a lot of heat circulated through the box I have pulled boxes out  of bars that hadnt been in a shop for 2 or 3 years the nicotine was so built up it took a special cleaner and a full day to clean. Same with the cd players Everytime you open to insert another cd heat either escapes there or if elsewhere it pulls nicotine and crap into the machine. In a smoke filled bar the optics have to be cleaned monthly.  (what does it do to the laser penetration?)
Cd's are more tolerant of heat but are still vulnerable to it. Never leave in a vehicle in summer. A jewel case always is dust proof never bends or puts  a rub on a cd.
The shack has a cleaner which should be applied in small amounts
and the cd should be cleaned or rubbed from the hole or inside to the outer edge. Any cleaner with a small amount of grit can be used  I think Lonnie even mentioned Brasso once.  There are those like timberlea on here that have cd's in the same shape as when they bought them years ago. (He has more patience than I do!!) LMAO
Now I'm goin back to digital... LMAO
PostPosted: Wed Jan 02, 2008 11:23 pm
Thanks for your advice!  I bought some slim jewell cases from Best Buy since I had a few Reward Zone coupons...  I think they will be safe now and I agree about the sleeves, even though they are lighter there is sliding in and out and the jewell cases hold them in place without the sliding.
Thanks again for the advice!
Tim
Users browsing this forum: No registered users and 3043 guests
