KARAOKE SCENE MAGAZINE ONLINE! - bbe max com dual channel compressor Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Fri Nov 06, 2026 9:36 pm
PostPosted: Thu Dec 13, 2007 10:51 am
anyone used this unit, would this replace my seperate bbe362 and seperate compressor
PostPosted: Thu Dec 13, 2007 11:29 am
If you are using the 362 on the mics only, then yes it would just replace, if you are using it on the entire mix, then you would lose on both counts.  Compressor are typically put in the mic chain, not a huge need to compress the entire mix.
Users browsing this forum: No registered users and 2974 guests
