KARAOKE SCENE MAGAZINE ONLINE! - Powered monitor or Passive Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Sat Nov 07, 2026 12:34 am
PostPosted: Fri Nov 23, 2007 10:19 am
ok, need some help!
I HATE not being able to hear yourself sing, so I imagine a lot of others feel the same.
I run medium to large size areas.  I use two Peavey 900w amps.  One for my mains which are Peavey SP2gs and one for my two matching 18" subs.
on my mixing board,  I have a seperate control for a monitor speaker.
Now, Do I purchase a active monitor or can I get away with a passive and somehow split my amps?  I want to keep my costs as low as possible but I want the singers to be able to hear themselves clearly!!
please, help! thanks.
PostPosted: Fri Nov 23, 2007 1:56 pm
Been Liked: 4 times
For a monitor you dont need a lot of power. As a singer you are close enough to not need much. 900w of power from an amp would be massive overkill in my view.
Just for purposes of keeping everything simple and compact, I would use a powered monitor, even though that means two cables (signal and power) going to the speaker.
PostPosted: Fri Nov 23, 2007 5:22 pm
Powered monitor will be fine with a decent eq between them to help with feedback.
PostPosted: Fri Nov 23, 2007 5:31 pm
nmnmmnmm.
PostPosted: Fri Nov 23, 2007 7:27 pm
Things aren't always what they seem. I will assume that you are running one PV900 in stereo to your SP2G's. If that is the case the SP2G is rated at 8 ohms, and at 8 ohms the pv900 is only rated at 180 watts per side. I would run your SP2G's in parallel off from one side of the amp which will lower your resistance(ohms) to four. At four ohms the PV900 is rated at 300 watts per side. So your talking 180 watts per side @ eight ohms or 300 watts per side @ four ohms. As neither of these figures is exactly over powering ( with the speakers you are using your actually seriously under powered no matter which way you configure it. I'd be on the look out for clipping.) So you might as well run half the PV900 for your SP2G's and the other half run to a monitor. We will assume your monitor will be rated at eight ohms also so you are only running 180 watts to it, once again not exactly over powered for a monitor. perhaps in the future you can add a second monitor lowering your resistance to four on the monitor half of the amp also. you didn't mention which bottoms your using, but there again, if the bass cabinets are rated at eight ohms each and you are running the amp stereo your only getting 180 watts per side out of it. For the bottoms( If they are 8 ohm each) I would bridge the amp and once again run the two bottoms in parallel. The PV900 is rated at 900 Watts bridged at 4 ohms. which is almost three times higher than you get running it at 8 ohms stereo. In any case, you can use what you already have and  perhaps even a little more effeciently than you have been. I hope I helped shine a little light for you as my fingers aren't used to working this hard LOL .
PostPosted: Fri Nov 23, 2007 8:36 pm
pretty well explained! most people do not understand that they can actually make more power safely by getting impeadance right.
PostPosted: Sat Nov 24, 2007 12:22 pm
Check out the TAPCO THUMP at www. sweetwater.com, it is a powered 15 inch speaker/monitor designed by mackie with a 3 band eq on the back for $349.00. I have heard these speakers and if i didn't already own 2 mackie srm-450s for monitor use , i would seriously consider these, and they are getting great customer reviews for the money. :read:  :wave:
Users browsing this forum: No registered users and 3261 guests
