Hooked up an old 4 channel mixer to Dell computer line in
https://ksmo.us/forums/viewtopic.php?f=1&t=11337
Author:  Steven Kaplan [ Fri Nov 09, 2007 3:07 pm ]
Post subject:  Hooked up an old 4 channel mixer to Dell computer line in
Teac M-09 Mixer, 4 inputs, line/mic inputs, buss-in, line out/aux. out
double RCA outs to line in computer stereo
do I set input to LINE-  ATTEN- or MIC ?
Author:  Lonman [ Fri Nov 09, 2007 3:10 pm ]
Post subject:  Re: Hooked up an old 4 channel mixer to Dell computer line in
The soundcard?  I'd put it on the line input.
Author:  Steven Kaplan [ Fri Nov 09, 2007 3:41 pm ]
Thanks Lonnie..  Dell stock whatever came with it...( integrated AC-97) ?   Standard chip with Dell Dimension 2350
Author:  Steven Kaplan [ Fri Nov 09, 2007 3:43 pm ]
I heard nothing on line... perhaps because SM-58 is going in standard 1/4 out mic cable into mixer 1/4 Mic in... I need to have switch to mic ?  I have no idea what mic attenuator means.
Would I do better to put one of the XLR cable on this microphone and use my XLR to 1/2 imp converter ?
I'm going 1/4 into this mixer, and stereo 1/8 line out into computer line in
Author:  Lonman [ Fri Nov 09, 2007 4:02 pm ]
Make sure the line input is turned on on the soundcard & not muted.  Double click the little volume icon on the task bar in the bottom right corner next to the time/date.  This should bring up the sound card audio properties.
Author:  Steven Kaplan [ Fri Nov 09, 2007 4:52 pm ]
It does assuming I have it on the microphone setting Lonnie..
thanks
Author:  Steven Kaplan [ Fri Nov 09, 2007 4:53 pm ]
Is attenuator on the same as line level ?  Should I switch from mic to mic atten ? for higher output ?
