KARAOKE SCENE MAGAZINE ONLINE! - Hooked up an old 4 channel mixer to Dell computer line in Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Fri Nov 06, 2026 11:55 pm
PostPosted: Fri Nov 09, 2007 3:07 pm
Been Liked: 11 times
Teac M-09 Mixer, 4 inputs, line/mic inputs, buss-in, line out/aux. out
double RCA outs to line in computer stereo
do I set input to LINE-  ATTEN- or MIC ?
PostPosted: Fri Nov 09, 2007 3:10 pm
The soundcard?  I'd put it on the line input.
PostPosted: Fri Nov 09, 2007 3:41 pm
Thanks Lonnie..  Dell stock whatever came with it...( integrated AC-97) ?   Standard chip with Dell Dimension 2350
PostPosted: Fri Nov 09, 2007 3:43 pm
I heard nothing on line... perhaps because SM-58 is going in standard 1/4 out mic cable into mixer 1/4 Mic in... I need to have switch to mic ?  I have no idea what mic attenuator means.
Would I do better to put one of the XLR cable on this microphone and use my XLR to 1/2 imp converter ?
I'm going 1/4 into this mixer, and stereo 1/8 line out into computer line in
PostPosted: Fri Nov 09, 2007 4:02 pm
Make sure the line input is turned on on the soundcard & not muted.  Double click the little volume icon on the task bar in the bottom right corner next to the time/date.  This should bring up the sound card audio properties.
PostPosted: Fri Nov 09, 2007 4:52 pm
It does assuming I have it on the microphone setting Lonnie..
thanks
PostPosted: Fri Nov 09, 2007 4:53 pm
Is attenuator on the same as line level ?  Should I switch from mic to mic atten ? for higher output ?
Users browsing this forum: No registered users and 3660 guests
