| Filler Music in m4p Format https://ksmo.us/forums/viewtopic.php?f=1&t=10851 |
| Author: | Texas Gigi [ Fri Sep 14, 2007 6:17 am ] |
| Post subject: | Filler Music in m4p Format |
Okay, so we are using Winamp with AutOKdj and we are doing a "theme" show--South Pacific, to be exact. I want to download some songs from iTunes to my handy-dandy iPod and toss them on the system for filler. Yes, we still use filler music, and no, it is not up for discussion in this thread. I have just begun playing with it at home, but Winamp doesn't acknowledge the existence of the m4p files on my PC--kind of like an ex-boyfriend. Is there a plug-in? Should I convert the files, and can I do it in Audiograbber or something else? Should I spend more time trying to figure it out because it is a stupidly easy fix? The show is tomorrow night and I will just die if I cannot play Bali H'ai and Girl from Ipanema.
| Author: | DannyG2006 [ Fri Sep 14, 2007 4:13 pm ] |
| Post subject: | Re: Filler Music in m4p Format |
Check this out: http://www.xilisoft.com/audio-converter.html Maybe this is what you are looking for. |
| Author: | Tigrr27 [ Fri Sep 14, 2007 4:54 pm ] |
yeah I had to pause when I ran into some music I had in MP4 format but luckily the software I use recognizes and plays mp4 music and karaoke files (zipped too)... I did have to use a converter though when I switched to a machine that did not have the software I used installed... good luck... tig |
| Author: | joy5022003 [ Sat Sep 15, 2007 6:41 am ] |
Hey there. If you put those songs into your Itunes player, then hit advance at the top, there is a option to convert to MP3. Under the original song will be the MP3 version. I ran into this problem a few days ago and that worked well. Joyce |
| Author: | RLC [ Sat Sep 15, 2007 8:27 am ] |
joy5022003 @ Sat Sep 15, 2007 8:41 am wrote: Hey there. If you put those songs into your Itunes player, then hit advance at the top, there is a option to convert to MP3. Under the original song will be the MP3 version.
I ran into this problem a few days ago and that worked well. Joyce It is my understanding that the process you eluded to will only work with non-protected m4p songs. The one sure way I know of (and this also works for protected wma files ) is to burn the songs to an audio cd and then rerip them as mp3s using a program like Audiograbber. |
