how can i load karaoke songs from cd+g disk to files in my laptop
https://ksmo.us/forums/viewtopic.php?f=1&t=10829
Author:  Doug Demott [ Wed Sep 12, 2007 12:57 pm ]
Post subject:  how can i load karaoke songs from cd+g disk to files in my laptop
can you help me figure out which drive i need to pull karaoke songs from my cd,s to a play list in my laptop. i have a lenevo think pad
Author:  knightshow [ Wed Sep 12, 2007 2:09 pm ]
Post subject:  Re: how can i load karaoke songs from cd+g disk to files in my laptop
you have to have a burner capable of reading the subcode of the karaoke file to play them off the hard drive.
I use audiograbber to do the karaoke ripping to mp3+g...
do some searching on the archives... you'll see this mentioned several times!
Author:  adam2434 [ Wed Sep 12, 2007 4:45 pm ]
I just started this process myself.  I stared with Audiograbber (freeware), but got some jumbled text.  So I bought Powerkaraoke CDG Burner for $40...no jumbled text so far, but it I have had some problems with the last track of a few discs getting a bunch of high level digital noise added to the end of the track.  I went back and did those with Audiograbber.
My laptop will not rip the graphics, but my old desktop will.  You will know it worked if you don't get ASPI errors and if you are able to create .cdg files for the graphics.  I'd try Audiograbber first to see if your your drive will work.
Also, I use Winamp with the CDG plugin to play Karaoke mp3/cdg's from my laptop.
Author:  powerkaraoke [ Thu Sep 13, 2007 6:29 am ]
These were probably multisession discs -- you may use 'Enable multisession disc detection' option in Settings dialog for such cases.
Author:  adam2434 [ Thu Sep 13, 2007 7:32 am ]
Sorry to derail the original post a bit...
What exactly is a multisession disc?  And can I keep that function enabled as the default since I don't know how to tell if it's multisession ot not?
The tracks that get the noise added to them show up as several minutes longer in the track listing screen.  But thus doesn't happen with Audiograbber for some reason.  Nonetheless, I'll try your reco and report back.
Author:  Doug Demott [ Thu Sep 13, 2007 9:18 am ]
my dvd cd rw drive will not lift the grafics off of a cd+g disc even with audiograber. does this mean i will have to purchase a stand alone cd+g drive and if so what are some good brands for around 250.00 or so.
Author:  Jian [ Thu Sep 13, 2007 6:59 pm ]
You need to find out if your dvd writer can read the graphic subcode. I do with Nero toolkit. This is how it look:
Drive Information
Drive                                        : TSSTcorp CD-R/RW SH-R522C
Type                                         : CD-RW Recorder
Firmware Version                             : TS04
Buffer Size                                  : 2 MB
Date                                         : ?
Serial Number                                : ?
Drive Letter                                 : F:\
Mechanism                                    : Tray
Read Speed                                   : 52 X
Write Speed                                  : 52, 48, 40, 32, 24, 16, 10, 8, 4 X
Read CD Text                                 : Yes
Return C2 Pointers                           : No
Read CD-R                                    : Yes
Read CD-RW                                   : Yes
Read DVD-ROM                                 : No
Read DVD-RAM                                 : No
Read DVD-R                                   : No
Read DVD-RW                                  : No
Read DVD+R                                   : No
Read DVD+RW                                  : No
Read Digital Audio                           : Yes
Read CD+G                                    : Yes
Read VideoCD                                 : Yes
Author:  powerkaraoke [ Fri Sep 14, 2007 3:29 am ]
Multisession discs have additional data or audio session. This looks like a regular disc to karaoke and CD players, but computer drives are confused (what is it for I am not sure -- maybe to prevent copying such discs).
You may have 'Enable multisession' on at all time -- it is disabled by default because it may cause problems with FreeDB access on some machines. If you do not experience such problems there is no need to switch it off.
Author:  timmyt [ Fri Sep 14, 2007 12:01 pm ]
all you need is http://www.powerkaraoke.com/src/prod_powercdgburner.php
(power cd+g burner) it will let you rip from a cd and then you can use mp3+g tools to convert it to a bin file or mp3+g or zip file.
let me know if you have any questions i do it all the time and you can do this with any cd burner
tim
Author:  DannyG2006 [ Fri Sep 14, 2007 12:15 pm ]
tim
I will echo this with a disclaimer that while it does a great job copying any and all cdg's it uses freedb which may or may not have the disc info available to name the fiiles so you may have to name the files yourself.  Get KJpro and cdgautoname f you can get it for these discs that may not be accessful via freedb but might be available on KJpro's database. I will say this - The quality of the rip rivals the rip you woulfd get with Hoster.
