KARAOKE SCENE MAGAZINE ONLINE! - Behringer FX mixer setting for Karaoke Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Fri Nov 06, 2026 12:09 pm
PostPosted: Sat Aug 18, 2007 7:24 pm
I am using a Behringer 1222-Pro Mixer for my home karaoke.  I am not sure which FX preset to use.  Anybody out there using Behringer mixer have any recommendation?  Thanks.  The karaoke machine I was using before have a echo switch to turn up the echo.
PostPosted: Sun Aug 19, 2007 1:15 am
Whatever happens to sound good for your voice & particular song.  No reall ONE preset that works with everything.  Play with it!
PostPosted: Sun Aug 19, 2007 1:55 am
I don't know what you are looking for, and I don't know the presets on the 1222.
The way they work for Behringer is that they will list a number for an effect, then following unlisted numbers are the same effect with different parameters (i.e. longer tail, greater delay, etc.)
On my PMH3000, I usually use the second "Room" reverb, #10, or the plate #3 for vocals. If you want delay reverb, 76 or 77 works fine. But I doubt those numbers match your mixer, so you will have to play with it.
Users browsing this forum: No registered users and 3293 guests
