| How do you add the dancing meez figures to your profile? https://ksmo.us/forums/viewtopic.php?f=1&t=10435 |
| Author: | oneofakind864 [ Mon Aug 06, 2007 1:00 pm ] |
| Post subject: | How do you add the dancing meez figures to your profile? |
I finally earned enough points to do it Yayyy! Got my meez all ready...now I just need to know the hows. Is there a size limit? .... and if so can you compress the meez? How is this done? Once they are the correct size- how do you add them? Help! |
| Author: | eben [ Mon Aug 06, 2007 1:20 pm ] |
| Post subject: | Re: How do you add the dancing meez figures to your profile? |
Hey. The Meez things are created at the Meez site. You have to sign up there and create an avatar/picture. Once you saved the image, you will get a embedding command from Meez, which you use to embed the image to any web site, including this one. |
| Author: | oneofakind864 [ Mon Aug 06, 2007 1:29 pm ] |
are there size restrictions in here? And do I have to embed the meez into every post? or can you set up your profile to automatically do it for you? I already created the meez. I just wasn't sure what to do with the code. |
| Author: | Jian [ Mon Aug 06, 2007 3:25 pm ] |
I just sent you some points to work on; just in case you need extra. |
| Author: | eben [ Mon Aug 06, 2007 3:58 pm ] |
oneofakind864 @ Mon Aug 06, 2007 1:29 pm wrote: are there size restrictions in here? And do I have to embed the meez into every post? or can you set up your profile to automatically do it for you? I already created the meez. I just wasn't sure what to do with the code.
The size is determined by Meez. You just link the code of the size you want and it shows up. You can edit the picture yourself if you want to use it as an avatar since they have size limitation. Otherwise, just default size. |
| Author: | oneofakind864 [ Tue Aug 07, 2007 11:51 am ] |
OK I DON'T want to use it as a avitar- but where do you add the link from meez? Is it in your signature box? |
| Author: | eben [ Tue Aug 07, 2007 2:02 pm ] |
Yes, you can link it in your signature box. |
