KARAOKE SCENE MAGAZINE ONLINE! - Cabling from Mixer to AMP to Speaker Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Sat Nov 07, 2026 8:54 am
PostPosted: Mon Aug 13, 2007 8:34 pm
Hello all,
I am very confuse with what cable should I get.  Here is what I have.
Behringer 1222FX mixer --> AMP --> Yamaha BR12
The AMP has CH1 and CH2 for both Input and Output.  For Input, it can take 1/4 or XLR and output is Banana.  (I think)
So, I need XLR(F) to XLR(M) from the mixer to AMP, and Banana(M) to Speakon from AMP to speakers.  Is that correct?  Is the XLR to XLR cable likes the one use for Mic?  Any low budget good cable recommendation.  Thanks.
PostPosted: Tue Aug 14, 2007 1:26 am
ultraming @ Mon Aug 13, 2007 8:34 pm wrote:
Hello all,
Well if the mixer & amp has XLR outputs & inputs, then yes use XLR cables (mic cords work fine, just use the shortest run that you need) for that run.  What amp are you running?  It should at least have banana & 1/4" maybe even Speakon if it's a newer type.  The speakers only accept 1/4".  You could go the banana to 1/4" - this would be the cheapest route or you could run 1/4" - 1/4 inch if the amp has 1/4" outputs.  If it has Speakon outputs, i'd go Speakon to 1/4" cables.
Get at LEAST a 14 guage or lower (in number) speaker cable.  Anything over 25 feet, get a 12-10 guage speaker cable for maximum efficiency.
PostPosted: Tue Aug 14, 2007 7:39 am
Thanks.
Do you know anywhere I can get a good short xlr-xlr cable (3 ft) ?  I tried look for it from various online music store and their review are pretty bad on the xlr cables.  Thanks.
PostPosted: Tue Aug 14, 2007 10:39 am
Good cables aren't really cheap.  What kind of reviews were you reading?
http://www.americanmusical.com/Item--i-CBI-MLN03.html  3' cable
http://www.americanmusical.com/item--i-MON-MSLX1.html  3.5' cable
http://www.americanmusical.com/item--i-MON-500M5.html  5' cable
For a non-moving connection such as the link between mixer & amp, any of these should do just fine.
PostPosted: Tue Aug 14, 2007 12:04 pm
Ultraming, Go here to get your XLR cables.
http://www.markertek.com/CatList.asp?ca ... ch=0&off=0
And you should be able to find an inexpensive set of speaker cables here.
http://www.pssl.com/csearchresults.tpl~ ... r%20Cables
PostPosted: Sat Aug 18, 2007 2:37 pm
Consider placing your amps near your speakers where you can use fat, high quality short speaker cables.....Then use cheaper long mic cables to feed signal to the amps from the mixer....A poor man's snake.
I bought a pair of 50 Mogami mic cables several years ago just for this purpose and they really made all the difference.
PostPosted: Sat Aug 18, 2007 3:17 pm
Been Liked: 8 times
oh
my
goddess!!!
YOU ARE BACK!!!! Welcome back Keith we all missed ya sooooooooo much
PostPosted: Sat Aug 18, 2007 3:27 pm
Thanks, Sweetcheeks.
I'm out on parole, so don't lead me astray.
I ain't supposed to be on the internet cause I had to register as a sex offender even tho she was almost 30.  :O
How ya been?
PostPosted: Sat Aug 18, 2007 3:34 pm
Been Liked: 8 times
this could get confusing will answer all questions on your own thread :)
Users browsing this forum: No registered users and 3678 guests
