KARAOKE SCENE MAGAZINE ONLINE! - Dimmer Hum Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Fri Nov 06, 2026 10:56 am
 Post subject: Dimmer Hum
PostPosted: Mon Jul 30, 2007 1:45 am
Is anyone else having trouble from a Bars light dimmers noise in your system? Any remedies? My system is totally balanced but I have one bar that I just can't seem to get away from the problem.
 Post subject: Re: Dimmer Hum
PostPosted: Mon Jul 30, 2007 2:59 am
the hum is from improper grounding.
If you get a "ground loop isolator" from Rat Shack, this has helped the battery hum for laptops as well as some venues that have older or improper wiring.
PostPosted: Mon Jul 30, 2007 3:47 am
Been Liked: 8 times
I had exactly the same prob until someone suggested that everything needs to be plugged into the same circuit...I run powered speakers and depending on how many rooms are opened up at the restaurant...sometimes my FOH speakers can be miles away...I used to plug them into the nearest socket...and I inevitably got a hum. By running them all back to the one socket and plug board it eliminated the problem.
It means that I have to spend extra time and effort with extension cords and taping them down but it does work, I havent had a prob since
Users browsing this forum: No registered users and 3057 guests
