KARAOKE SCENE MAGAZINE ONLINE! - player no karaoke Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Fri Nov 06, 2026 10:58 am
 Post subject: player no karaoke
PostPosted: Sun Jun 10, 2007 2:01 pm
Hello I have a dvd/vcd player that does not have the microphone/karaoke input/port, I am wondering is there a way that I can make it to be my karaoke meachine? like a plug-in? or part that I can purchase?
 Post subject: Re: player no karaoke
PostPosted: Sun Jun 10, 2007 2:08 pm
Unless it reads CD+G subcodes then you won't be able to get karaoke out of your player. Although you might be able to play VCD or DVD karaoke discs.
PostPosted: Sun Jun 10, 2007 3:50 pm
Like stated unless you are going to be using DVD or VCD discs which are not too common as the standard CDG, you aren't going to have much of a karaoke machine.  You don't really need a microphone port, you could just buy a small mixer, then you plug your player & mics into the mixer.
http://www.musiciansfriend.com/product/ ... sku=630156
Now if you needed a key changer ability, then you would need an external adapter.
http://www.karaokewh.com/item_details.c ... raoke.html
Pretty expensive however at $189 just for the key changer.  You could get a real karaoke player for about the same price.
http://www.soundchoicestore.com/pck-300 ... 33703.html
Now this does come with mic inputs on the player, but really mic inputs built into the players aren't very good sounding to begin with - the separate mixer would give you nicer sound & more controllable.
PostPosted: Mon Jul 16, 2007 11:15 am
Hello, so I can buy a mixer, then I can plug my dvd player and a microphone to that mixer, then I can sing along just like karaoke machine on that microphone. I don't mind about keychanger. I just want to sing lol..
PostPosted: Mon Jul 16, 2007 11:28 am
Oh I found this one on the Internet, and it is the thing that I want my player to be, yeayh http://www.acekaraoke.com/hprdkmmor1.html
but I am not sure if this is worth it or not? Or if I buy a mixer , would it do the same thing?
PostPosted: Mon Jul 16, 2007 12:57 pm
Not worth it.  Mixer for a little more, would do a better job as far as sound controllability.
PostPosted: Mon Jul 16, 2007 1:02 pm
As many have said, you can play DVD or VCD based Karaoke discs using the machine, and the device you have listed. The CD+G discs, which tend to be more available in song titles, etc. would not play.
Exception is that if your player can play CDs and have a digital code output (you can find this out quickly in your manual or back of the machine where it will say digital code output), you can buy an external CD+G decoder that will also function as a mixer for your mic, key change, have effects built in etc. I have only seen a few of these and they go for at least $300 or so but if you want to keep the machine, this may do it. I can't recommend any brands since I haven't used it myself but here isone example of such device.
One thing nice about this is, and I would only say it's for home use, not for professional use, I can hookup my Sony 300 CD changer to it and never have to fiddle with my discs. I may end up getting one of these and set it up my home system so I can put all my disc and use it as a jukebox type of thing.
Seize the day and SING!!!
PostPosted: Mon Jul 16, 2007 1:12 pm
Problem with the cdg decoders, they don't work with all players even alot with the digital outs.  Some work fine, other work so-so - graphic glitches & lagging lyrics, many don't work at all.  Anything that does work MUST have a 'digital shock buffer' (don't ask me?) built inline with the digital output in the player.
Users browsing this forum: No registered users and 2998 guests
