KARAOKE SCENE MAGAZINE ONLINE! - Video Out Put Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Thu Oct 22, 2026 10:24 pm
 Post subject: Video Out Put
PostPosted: Thu Nov 06, 2003 9:36 am
One good thing I liked about my Voco Pro mixer was the fact that I could have 2 video inputs and 2 video out puts - switched back and forth by a simple switch...Now that I am going to be STORING that mixer and using a dfx12 mackie which I doubt has any video capabilities .
What is available or WHAT DOES everyone use when you have 2 or more video sources going to the same monitor or monitors. Like in the event you have your cdg player , maybe a dvd player etc.?
is the answer just a simple A/B video switch from RAT SHACK? :oops: :oops:
PostPosted: Thu Nov 06, 2003 10:25 am
I use a rca video switcher/demodulator. It takes 4 inputs audio/video rca & s-video and will output to s-video, rca video and/or channel 3 or 4 .
I like the rca because it is digital and hasnt got any crosstalk between inputs. and has crisp clear outs.
PostPosted: Thu Nov 06, 2003 10:38 am
I use the simple 4 source video switch from Rat Shack. It is an all RCA input/output so all sources go into this first, then into the RF modulator so you only need 1. You can hook it up so just the video goes through it (which is what I do) or you can hook the audio of the players into it as well & run the audio out from the switch to the mixer.
PostPosted: Thu Nov 06, 2003 1:06 pm
If I had time - A real neat little toy is the Videonics MX1
Used for editing Audio/Video so you can roll (just one of the many editing features) the next screen in of out and you can superimpose. Choices of editing 4 channels audio or video-
It's a REALLLLLLLY fun toy - your friends will be amazed
The opinions of Sammy do not necessarily reflect the views of the Karaoke Scene Magazine - Advice is given with a sence of humor and should be taken accordingly - If you have problems setting the clock on your VCR - You've come to the right place
PostPosted: Fri Nov 07, 2003 8:09 pm
Rat Shack as Lonman says. Also simplified my (non-DMX) lighting switching with a gizmo from them.
Sounds Great! Entertainment
Bartlett, Illinois
Users browsing this forum: No registered users and 2777 guests
