Confusing Power Specifications
https://ksmo.us/forums/viewtopic.php?f=1&t=10091
Author:  jamkaraoke [ Tue Jun 26, 2007 7:13 am ]
Post subject:  Confusing Power Specifications
Need some expert deciphering of the following POWER specs for a POWERED MIXER.
It's advertised as a 1200watt powered mixer and I realize that's at 4ohms!!
So thats 2 x 600w at 4ohms  which  I normally would think is close to
2 x 300watts @8ohms.??? :thinkin:  :thinkin:  :thinkin:
PLEASE SOMEONE EXPLAIN THE FOLLOWING : ( NO NEED TO BASH BEHRINGER) JUST LOOKIN FOR AN EXPLANATION
Here is the link and I'm confused  :(  :shock:
http://www.musiciansfriend.com/product/ ... sku=630181
Output Power
RMS @ 1% THD (sine wave), both channels driven; 8 Ohm per channel: 165 watts; 4 Ohm per channel: 250
RMS @ 1% THD (sine wave), bridged mode:8 Ohm: 500 watts
Peak Power, both channels driven; 8 Ohm per channel: 225 watts; 4 Ohm per channel: 350 watts
Peak Power, bridged mode: 8 Ohm: 800 watts
Author:  karyoker [ Tue Jun 26, 2007 7:33 am ]
Post subject:  Re: Confusing Power Specifications
The 2 specs that glare out are.
# RMS @ 1% THD (sine wave), both channels driven; 8 Ohm per channel: 165 watts; 4 Ohm per channel: 250
# RMS @ 1% THD (sine wave), bridged mode:8 Ohm: 500 watts
In the bridged mode the output per channel is 250 watts...
Peak power is 1.4 X rms power pure and simple and precisely with a sine wave. With dynamic signals such as audio it varies with the peaks esp bass but the variance isnt that radical..
Author:  jamkaraoke [ Tue Jun 26, 2007 7:47 am ]
I went to the Behringer site and their specs make a little more sense  ( I think the specs shown on MF are wrong????)
Specs per Behringer site :
OUTPUT POWER
RMS @1%THD (sine wave) , both channels driven:
8ohms per channel   215w
4ohms per channel   450w
Peak Power is listed "per channel"  as
300w for 8ohms
600w for 4ohms
These numbers are more in line with a 1200w advertised powered mixer?
Author:  karyoker [ Tue Jun 26, 2007 7:56 am ]
Yup it does make more sense 1.4 X 215 = 301 but I think they are giving bridged mode specs..
Author:  jamkaraoke [ Tue Jun 26, 2007 8:01 am ]
The bridged mode is listed as :
RMS 8OHMS 900W
PEAK 8OHMS 1200W
side note: It looks like a decent little unit for $400
Author:  karyoker [ Tue Jun 26, 2007 8:16 am ]
I had to do a quick refresher on bridging
tutorial
What happens when you bridge an amp?
 Theoretically, the output should be 4 times the power of a single channel on the amp. A 50Wx2 amp bridged would act as a 200Wx1 amp. Unfortunately, you only see about 2/3 to 3/4 of this power. This number is usually the same as the combined power of the 2 channels at half the load. Take the following example of a 2 channel car stereo amplifier:
I really didnt look at the other features (could be a buy) but it would depend on the size of venue as far as watts is concerned.
Author:  jamkaraoke [ Tue Jun 26, 2007 9:10 am ]
It's a small venue and I'm looking to be able to leave something their on a permanent basis ?  Power wise it would be ok and price wise not to expensive (just in case )  Thanks for your input
