KARAOKE SCENE MAGAZINE ONLINE! - speakers Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Thu Nov 05, 2026 1:02 am
Post new topic Reply to topic  [ 87 posts ]  Go to page Previous  1, 2, 3, 4, 5
 Post subject: Re: speakers
PostPosted: Mon Nov 27, 2006 1:36 am
:worship:
Excellent advice Kappy.   You sound like someone I know very well. LMAO
PostPosted: Mon Nov 27, 2006 7:29 am
Been Liked: 11 times
If I go out in public, I try to dress presentably, comb my hair, brush my tooth, etc.
Same goes for my sound when I perform in public.  In such a case I have even more responsibility to paying patrons IMO. My presentation is how I will be known. If you host music as a profession,  by definition of "profession" you SHOULD take pride in your work and make the best presentation you can.  Your sound system matters, as does your ability to set-up and use the system you own.  If you feel you can't do the greatest job alone,  have someone else who does what you can't with you. IT'S YOUR SHOW !  Take pride in it.
My OWN feeling, is that if you are in an area of "art" that involves sound, KEEP your aesthetic areas of sensitivity developed to better appreciate this artistic area. Try to even tweak your home system to sound the best it can in a room,  don't learn to settle for poorer sound quality. An artist appreciates the finer areas of his craft IMO...  If as a performing artist, your instrument is CD/Tape or turntable.. Play it well.
PostPosted: Mon Nov 27, 2006 8:15 am
Does anyone know of or have an opinion about this product?[/quote]
Makes a great monitor system, would I use for club mains - no.  Known a few that have owned these trying to do clubs with them, they either ended up taking them back for more powerful gear or they added powered subs which defeats the portability factor, still not as bad, but....For home use, it would be fine.
The Passports that use the Bose designed speakers are the 'deluxe' PD models.  The lower P models do not.[/quote]
Hi:
Any idea about JBL JRX125 with dual 15" for KJ?
PostPosted: Mon Nov 27, 2006 8:50 am
Matching Amps and Speakers:
When looking at buying speakers it can be confusing trying to figure what is the best speaker for your application. Speaker ratings are confusing; some are listed at 500 watts program – 1000 watts peak, some list “continuous” watt ratings.
The suggested match up is to use an amp that is listed as twice the watts as your continuous rating on your speaker.
Currently I am using the Yamaha SV15 with a Crown XLS602 amp rated at 380watts x 2 @8ohms. The rating on the speakers are 500/1000 program/peak
Am I “under powering” these speakers?
I have had no problems so far but I am looking for another set of speakers and wonder if I am better off using the Yamaha BR15(or similar)  which is rated at 250/500 program / peak?
PostPosted: Mon Nov 27, 2006 8:54 am
Hi:
Thanks[/quote]
Don't use a dual 15" for karaoke.  Reason being you need to get your mains up over the crowd, these a floor speakers & unless you have a rather high stage to work with, it isn't going to produce much sound, especially in the back.
Recommend (if you want to stay with JBL) JBL JRX115 mains on stands & JBL JRX118 subs.  With ANY speaker you want to make sure you have the correct power pushing them.  The 115 need 500 watts per speaker into 8 ohms.  The subs need 700 watts per speaker into 8 ohms - now to save money here & still sound great, you can get an amp that pushes 1400 watts into 4 ohms BRIDGED then run both speakers paralleled in bridge mode.  This means you will need 2 amps & external crossover.  Systems like this is more versatile to play in difference sized rooms.
PostPosted: Mon Nov 27, 2006 9:37 am
Thanks a bundle Lonman...I have a lot more to learn from the pro...
PostPosted: Sun Dec 03, 2006 5:24 pm
if youre live
Gemsound PS15
peavy 12 or 15's (always great quality)
american DJ, behringer etc, all make decent cabs
(this is NOT an advert!! - -)
djtronix offer free shipping and have a budget range (considering youre in the US)
can actually get a decent set of gemini with covers and stands for $400, this is definately budget when you consider what you get. Ive tried similar speakers, and whilst they wouldnt blow out the windows theyll certainly do the job
Users browsing this forum: No registered users and 1771 guests
