KARAOKE SCENE MAGAZINE ONLINE! - Help! Need a sound lesson! Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Mon Nov 02, 2026 4:35 pm
Post new topic Reply to topic  [ 64 posts ]  Go to page Previous  1, 2, 3, 4
PostPosted: Thu Dec 30, 2010 1:53 pm
Yes, the console was run reduced and luckily, no hum. That would drive me nuts (but might be easier to fix). I will have to look into what lines I am using (balanced or unbalanced).
I really appreciate your advise, thanks.
Kevin
PostPosted: Thu Dec 30, 2010 5:12 pm
Remember it is not reducing your volumes on the board.
You need to keep your volumes
and reduce your gains.
PostPosted: Thu Dec 30, 2010 6:57 pm
This is easy to understand
http://www.globalrph.com/speaker_maximum_output.htm
PostPosted: Thu Dec 30, 2010 7:16 pm
Yeah, look to see if your are using balanced cables or not.
Not sure of what all you got in the signal chain, but if it's more than a simple mic(or cd) >mixer>amp>speakers, unpatch everything from the simple chain I just described. Set board eq's to mid point.
Once you are back to basics consisting of mic(or cd), mixer and amp, then patch in just one additional component and listen....if you lose clarity or pick up noise then, it's either cables or that component's gain structure is out of whack. It might also be that the component has very narrow dynamic range.
Letitrip is most correct that a change in eq will disturb gain structure....After all, a boost is a boost, and a cut is a cut in signal strength, huh?....
So start with strip eqs flat(mid point or 0), increase your strip input gain to just under 0 on PFL meter, or lower if input clips, open amp gains to max, set masters to 0, then raise strip slider to decent listening level and listen.
From there, reduce strip input gain as you increase strip slider to maintain loudness and see if it sounds clearer. If it does, your input gain was too high.....
If there was no change in clarity and it sounds clear nuff, then tweek eq while you PLF that strip...watch the meter and listen to see if it loses clarity. The PFL meter should increase and decrease as you boost or cut the eq.
Users browsing this forum: No registered users and 1751 guests
