KARAOKE SCENE MAGAZINE ONLINE! - Help me to pick a good Microphone for home entertainment Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Fri Nov 06, 2026 3:20 am
Post new topic Reply to topic  [ 70 posts ]  Go to page Previous  1, 2, 3, 4
PostPosted: Sat Jul 19, 2008 12:40 pm
Don't know if that mixer will work -- I guess it will since my SYM-600 did. But if it doesn't, you just buy:
http://www.zzounds.com/item--BEHMIC100
PostPosted: Sat Jul 19, 2008 12:42 pm
Or you could buy the good and ($20.00) cheap Behringer XM-8500. If that works, the SM58 will work. Then when you are ready to upgrade from the XM8500, go for it, and use that as your second mic!
PostPosted: Tue Jul 22, 2008 4:20 am
I second the Sennheiser 835s. I've used SM58 all my life but the Sennheiser just cuts through. It may be better suited to male vocals though. You could try the 845s for female vocals as it's abit fuller in the lower frequencies.
I like to alternate between mics if I'm forced to sing myself and find all 3 types are great.
My 2 pence.....hey I'm English :P
Gadget's Karaoke : Boldly singing what no one has dared sing before.
PostPosted: Tue Jul 29, 2008 3:04 pm
I can't seem to find another thread where we discussed mics, so I'm posting here.
I picked up a Shure PG58 wireless mic to use in my karaoke show. Is this an alright mic?
hi-voxentertainment
PostPosted: Tue Jul 29, 2008 3:10 pm
My mixer/amp has both XLR and 1/4 capability. I did at one time have an adapter that went from 1/4 to XLR. It worked great.
PostPosted: Wed Jul 30, 2008 9:50 pm
Discusman @ Fri Jul 18, 2008 5:55 am wrote:
Is PG58 the same as SM58?
No, i happen to have both, the PG is a little more muddy than the SM. SM58 is ok, I think there's a "clone" floating around on ebay that sounds close to the SM58 for like 30 bucks, people from recording forum said they sound pretty dam close. I personally would probably get the sennhensier mic (E835), they're a little more open. Or maybe the shure beta
I really think the SM58 sound ok live once you pump enough gain into it, it sound like crap when it's at small volume.
Perhaps you want to try the electro voice mic, musician friends is bringing back the classic EV dynamics and it should start selling them soon. I just recieved the booklet from MF advertising them, looks pretty good IMO.
The next step up would be the SM7, although I don't see how you can hold on to that thing while singing.
PostPosted: Wed Jul 30, 2008 9:57 pm
MorganLeFey @ Sat Jul 19, 2008 2:04 am wrote:
It sounds very like a cable problem. the shures we bought 2nd hand came with xlr to jack cords that gave us the same problem. the home theatre system I was trying to plug in to practise with (we are talking long before I had my own pa system and was hiring one for the few gigs we got at the beginning)
A musician came one day and said it was due to the cord being either balanced or unbalanced...whichever way it went, (cant recall which it was now) he did a bit of rewiring and bingo we had a beautiful volume level.
balance and unbalance cable is real easy. most of the time you'll want balance, there's technical aspect about the differences that I won't get into (not qualify and frankly I don't understand most of it haha), but at any rate, balance cable will let you use longer cables without loosing signal quality, most microphone uses balance cable (TRS or XLR).
PostPosted: Tue Aug 05, 2008 2:34 pm
Hi Guys,
I bought the SM58 and I love it. The sound that coming out of the thing is amazing.
Thanks for all your advice and comments.
I think we gonna do karaoke everyday with this microphone. :P
PostPosted: Tue Aug 05, 2008 3:03 pm
To bore you guys with technical details. The reason you want to use a balanced cable is that your signal degrades a lot slower with it then using a unbalanced cable. The balanced cable uses what I learned as a differential transmission. You notice that balanced has 3 connectors? Well, the third connector is the ground that shields the pair of wires used for transmission. One wire will transmit the signal as is, second wire will invert the polarity of the signal and send it down the line.
Why is this better? Simply put, better noise immunity. There are two methods of differential transmission. For digital signal, this method was used in computer interface like SCSI interfaced used on disk drives, one signal goes from 0V to 5V, other goes from 0V to -5V. So, instead of just 5V differences in signal, you get 10V difference. If you see it on a oscilloscope, you will see that the digital signal will degrade in voltage and in width as you go further due to built in resistance of the cable. So, if there is a noise that is few volts, it will not interfere with the actual digital signal or give false data because the voltage of the noise was high enough to trigger the receiver. Bottomline is less, errors and better data. This is a better method when the data is 0s and 1s that travels.
For the analog signals, like the ones that goes from mixer to powered speakers, they use the same method to transmit, inverted signal on one cable. However, the recovery is different. What they do is, when they receive the signal at the other end, they invert the signal again and match it with the original signal. If there are any differences, that is the noise and you just cancel that out from the original signal and you have a much cleaner signal. So, now you can run longer and have more interference but you can recover a cleaner original signal from the transmission.
Compare this to two wired, unbalanced signal for analog signal. One wire is grounded and ther other one sends the original signal. Since the ground is stable, whatever noise added to the original signal is still there and difficult to filter out. So, they are less likely to transmit cleaner signal over a long distance.
If you can, I would highly suggest you use a balanced cable if you can, specially if your wiring is going over a power line or near a cell phone. They will protect your signal much better from interference over any distance.
Seize the day and SING!!!
PostPosted: Wed Aug 06, 2008 11:55 am
I think my cable is balanced cuz it has three connectors at the end that connects the cable and microphone.
Users browsing this forum: No registered users and 2027 guests
