KARAOKE SCENE MAGAZINE ONLINE! - Karaoke speaker question Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Fri Nov 06, 2026 11:52 am
Post new topic Reply to topic  [ 67 posts ]  Go to page Previous  1, 2, 3, 4
PostPosted: Thu Aug 02, 2007 12:24 pm
Dennisgb @ Thu Aug 02, 2007 6:58 am wrote:
LondonLive @ Thu Aug 02, 2007 3:11 am wrote:
do yourself a favor and try and get your hands on a Allen Heath mixer to play with.
London,
Now I’m going to have to check out Allen Heath. Will I need to take out another loan? The wife will kill me… :shock:
http://www.allen-heath.com/US/DisplayPr ... p?pview=16
This is the perfect live sound/dj-kj mixer combo anyone could want.  But it has about a $1500 pricetag attached to it as well.
PostPosted: Fri Aug 03, 2007 8:12 am
Thank you for all the replies althought I don't understand most of the technical stuffs.  However, it is really good education to learn from the experts.  I will look for a new pair of PA speakers.
Couple of questions:  What is the difference between PA speaker and monitor speaker?  Can I use the monitor speakers as my main vocal speakers?  Also, when I hook up the mic to my mixer, should I connect to the mono jack or stereo jack?  Thanks.
PostPosted: Fri Aug 03, 2007 8:39 am
What do you guys think about Peavey PR10P for home use karaoke?  Thanks.
PostPosted: Fri Aug 03, 2007 4:33 pm
For the most part the difference between the two would be the design of the cabinet, the PA speaker more than likely has a provision to mount on a pole and both sides are cut identical. The monitor cabinet is designed to set on the floor and angled up at the performer, some newer types are made with the horn in the vertical position and are cut in a way that will allow a 60 degree angle or a 45 degree angle (roughly).In a lot of cases the internals of the cabinets are identical even though sometimes the monitor might have a tighter dispersion on the horn. I've seen some that are designed in a way that they could be used as a floor monitor or a pole mount frontal speaker.
As far as the mic, if you're asking that question i'd have to assume that your mic cable is a 1/4 phone plug verses a balanced XLR. To the best of my knowledge I would think the mono plug would be the choice as your mic would only have a mono 1/4 phone plug on it. The way to determine that would to look at the plug, if there is only one separation along the shaft it would be considered a mono Tip/Sleeve plug. If there are two separations on it, it would be considered either Stereo or balanced which would be a Tip/Ring/Sleeve.Thats my story and I'm sticking to it. :)
PostPosted: Fri Aug 03, 2007 4:38 pm
I think that the PR10P would do a great job for you, even though seeing how I'm the kind of guy I am for the 30 bucks difference I'd go with the PR12P. See how I am.
PostPosted: Mon Aug 06, 2007 6:32 am
That would be an excellent speaker. I'm wondering why you want to go with powered tho. Did you look at the link that I put up for you?
If your willing to spend this much, go for the 12's.
PostPosted: Sun Aug 12, 2007 4:37 pm
Thanks everybody.  I finally got a pair of Yamaha BR12.  Anybody has any experience with this one?
Users browsing this forum: No registered users and 3015 guests
