KARAOKE SCENE MAGAZINE ONLINE! - Help with finding a Subwoofer Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Thu Nov 05, 2026 8:03 am
Post new topic Reply to topic  [ 46 posts ]  Go to page Previous  1, 2, 3
PostPosted: Mon Apr 16, 2007 4:25 pm
UnHinged @ Mon Apr 16, 2007 3:46 pm wrote:
dbk1009 @ Mon Apr 16, 2007 3:02 pm wrote:
I know after using them for nearly 4 years, they will need to be replaced in the not too distant future. I appreciate the advice, but it still did not answer my question on wether or not the sub will enhance enough to make a diference.
BTW- I tried a BBE sonic Maximizer and saw no 'appreciable' effect.....
Yes subs would help.  I’m familiar with those mains you have and there’s just no bottom end.
Problem is, if you add a sub or subs of acceptable quality, then more amp, crossover if needed… you’re talking a substantial investment and more stuff to carry,
and even with the new thump, your tops will still sound bad.
Then you say you’ll still need new main speakers in the near future, which is another few-hundred $$, after which you may even regret having bought the subs.
You mentioned that you don’t want to invest much, so I’ll talk minimums here.
If you want decent passive subs, I’d recommend minimally the Peavey PR 15” Sub, or better yet, the Peavey PV118.  Both have internal crossovers.
As for powered subs, the cheapest I see is some Nady 15” for $349.99, and personally I wouldn’t touch it.  Next up you’re pushing $800.
In my humble opinon, here’s the most efficient way I can think of doing it.
First I’d get two new main speakers and see how they sound with your amp.  I’d bet money you’d find the difference to be AMAZING.
Then if you still want to add subs later, get one or two passive subs with internal crossovers and an amp powerful enough to run them all, you’re good to go.
The Yorkville mentioned earlier in this thread would probably do the trick & won't break the bank - not a real powerful beast, but is loaded with an Eminence driver.
If the sub is crossed over correctly & the Gemini's are no longer trying to reproduce the low end, they would sound alot cleaner.  Gemini speakers aren't really designed for live use, but more dj use.
PostPosted: Mon Apr 16, 2007 4:33 pm
UnHinged @ Mon Apr 16, 2007 4:16 pm wrote:
Yes, it is ideal to match the amps RMS/Continuous rating to the speakers “Program” rating.  Really, anywhere between the speakers RMS/Continuous (half of program), and Program rating is a good/safe rule of thumb.
Not to contradict, but as per my understanding, if you have enough volume, it hurts nothing to “under-power” a speaker.  This is a common myth.
As long as you aren't cranking the volume, yes you can go with a smaller amp, HOWEVER, most that are doing shows with smaller amps turn their systems up louder to compensate for crowd noise - which is where the amp starts clipping because it's trying to go past it's rated power - the volume may be there, but it is the form of tinny, distorted quality sound.
The problem people have is that, when they don’t have enough volume, they push something in the chain (mixer/amp/whatever) to clipping (red lights), resulting in a distorted signal which can easily double the strain on the speaker.
Right.
If the volume is sufficient and nothing is clipping, 50 watts in a 1000 watt speaker has no ill effects.
Unfortunately, the chances are slim that the volume output of smaller amp with a speaker needing more will be sufficient for most shows.
A 10 watt amp CAN in fact blow a 1000 watt speaker if it's driven to clipping.
Also, with that in mind, it’s almost for sure that those cheapo speaker companies use some very-creative (downright dishonest) means of measuring the efficiency of their speakers, which is another reason to stick with a name-brand like Yamaha or Peavey, or even Behringer.
THis i'm sure of.  ESPECIALLY with amp ratings, most of the cheaper brands will rate at the highest rating with the lowest load (or bridged rating if it's capable).  I've seen amps claim they are 500 watts per channel, well yeah that's peak power - not a continuous reading.  When it actually only puts out MAYBE 100 per channel & that's into the 4 ohm rating.  Cheaper speaker brands may put their peak rating on with no other rating so someone will think they are getting a 400 watt (peak rating) speaker, when it can actually only handle 200.
PostPosted: Mon Apr 16, 2007 5:01 pm
I’m glad we agree.  I appreciate your professional input as I’m always looking to learn more... (and intend to pick your brain more in the future).
I did learn one thing from another pro-sound forum from an actual Peavey engineer (speakers and amps) that I’d like to pass along.
Speaking correct/accurate ratings here… If there’s a clipped signal, figure “double” the stress on the driver (speaker).
Therefore, if the amp is LESS than half of what the speaker can handle, it won’t necessarily kill the driver.
For instance:
400 watts distorted signal into 400 watt speaker = damage
300 watts distorted signal into 400 watt speaker = damage
200 watts distorted signal into 400 watt speaker = dangerous
100 watts distorted signal into 400 watts speaker = no damage.
Good to know.
PostPosted: Thu Apr 19, 2007 11:33 pm
UnHinged @ Sun Apr 15, 2007 5:16 pm wrote:
JoeChartreuse @ Sun Apr 15, 2007 4:27 pm wrote:
I don’t think he was suggesting that the vocals needed the subs, but the music, which would enhance the singer‘s experience.
But… I still don’t use subs for strictly karaoke.  When I’m Djing, the music includes more hard rock and hip-hop, which have a lot of those lower frequencies,
but it just happens that, for some reason, karaoke singers seldom sing that; it’s more classic rock, oldies, soul, country, etc. and the music on the discs, more-often-than-not, simply don’t have those super-low frequencies to reproduce.
Now, if you DON’T have decent 15” speakers, then a sub would definitely help,
but if you have decent speakers, then the benefit of the subs for (I’m guessing) 95% of the songs would be negligible.
That would just me my experience, (your mileage may vary).
  We're pretty much in complete agreement. Remember, I DO use subs for straight DJ work....
PostPosted: Thu Apr 19, 2007 11:45 pm
Lonman @ Sun Apr 15, 2007 5:42 pm wrote:
I see plenty of places that don't run one & IMO the music doesn't sound full (without the aid of major eq'ing).  Also as a rule, many karaoke companies have the "Why buy good equipment" or " Why should I use that kind of equipment - it's only karaoke" mentality.  Not saying that's your stance, but I have seen that in person & even on this & other boards/forums.  Which is probably the reason why you see very few.
            I didn't state the vocals sounded thin, I stated the music sounded thin & yes this is due to inexperience or improper equipment.  Went to a show last night, the place was a fairly large place, 2 15" 2 way speakers on stands & a crappy little mixer amp that pushed aprox 100 watts per speaker.  There was NO bass & I saw his settings - the bass was turned up.  Distortion.  The addition of a powered sub (even 1) in there would have been a tremendous help, allowing more bass in the music & cleaning up the tops.
Most dj's that do karaoke as a sideline are also generally using the 'smile' setting on their eq - which automatically boosts the bass & treble up & cuts down the mids - which is where the primary vocal frequencies lay.  So yes I can see where you may think a sub is detrimental, but with a sub that is properly crossed over, powered & eq'd, I think you'd hear a different tune! :D
          I hate to blow a good debate, but it actually (with proper communication) looks like we're traveling slightly separate but parallel roads with the only difference being subjective opinions regarding the amount of bass we prefer. Guess we gotta leave it like that....        Couple of questions though: How did this guy with the toy equipment end up working in a professional venue in the first place?   Also, couldn't he hear what it sounded like?   :drool:
PostPosted: Fri Apr 20, 2007 1:34 am
Most likely becasue they are charging 1/3 of what a pro that knows what they are doing charges!  Which is the biggest (@$%&#!) among real kj's as opposed to wannabes, they charge less but people don't SEEM to care enough to not support them!
Users browsing this forum: No registered users and 2447 guests
