KARAOKE SCENE MAGAZINE ONLINE! - Noise from Laptop! Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Fri Nov 06, 2026 10:47 am
Post new topic Reply to topic  [ 76 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: Noise from Laptop!
PostPosted: Sun Feb 17, 2008 2:42 pm
Non-Member
sidewinder @ Mon Feb 11, 2008 4:46 pm wrote:
I just hooked up at a brand new bar.  New building and all, 6 months old.   All new HDTVs that need a special adapter box to change the signal to HDTV.  And i had to put in the audio and video isolators to STOP all the hum.   I will just leave them permanently hooked into my system and i won't have to worry anymore about any place.
It also stopped the ghost video interference on the TVS that kept rolling from top to bottom on the screen.
Yeah i do, i just went through the entire scenario.    The noise was coming from the audio and video ground loop.  So by isolating both of them without touching any of the "grounds" i fixed it. :O
Do you know what i'm talking about?
PostPosted: Sun Feb 17, 2008 2:48 pm
Non-Member
In fact i have several bars that i have to isolate the coax feed because of ground loop noise and some i don't.   But i just do it in the coax line.   I don't have to flip the plugs or drop the electrical grounds.
PostPosted: Sun Feb 17, 2008 3:03 pm
Sidewinder
No, Eric was talking about the hum from his laptopand the use of the Ebtech hum eliminator.
PostPosted: Sun Feb 17, 2008 3:42 pm
Non-Member
Ground loop is ground loop.  It comes from having conflicts with the elecrical signals.  From computers or disc players conflicting in the same electrical circuit as your amplifier, mixer, effects.  I use a laptop and that was the exact issue i had.   Whenever you hook everything up there is no issue until you connect the TVs.  That's when you get the noise. (Ground Loop)
PostPosted: Sun Feb 17, 2008 4:43 pm
Deleted by author -
PostPosted: Sun Feb 17, 2008 11:56 pm
Non-Member
Call this general information.
If the computer itself if humming without being hooked up to TVs or a PA system.  There is an electrical circuit problem or the computer has a problem.   Nothing should be humming just to hum.   If it does it in every electrical outlet you plug in to, there is a computer problem.   House wiring and bar wiring can be wired incorrectly.   They can have the blacks and whites wired backwards.    The ground wire may not be properly hooked up.  Could be a problem in the breaker box.   Call an electrician.
I use to carry a plug in circuit checker.  It has lights on it to tell you if the outlet was wired correctly.  Many bars were not.
If it does it only when it's hooked up to other things then the problem is an isolation problem.   Video and audio cables need to be isolated.
Just the computer humming by itself, i would take it back to be checked.
PostPosted: Mon Feb 18, 2008 9:37 am
Non-Member
I have 2 external hard drives and an external dvd drive hooked up to my laptop.  I wanted to run cooler fans under the laptop, so i use this to power the fans.  I didn't want anything else sucking power from the laptop.
This could possibly eliminate fan noise on the computer too.
AC to USB Power Adapter Charger
PostPosted: Mon Feb 18, 2008 10:09 am
From experience Lifting the ground on a lappie solves the noise problem. One power surge even a bad motor  in a walkin cooler starting and putting spikes on the line will fry it it. Get a hum buster from the shack.  It is nothing more than a 1/1 isolation transformer which dies not conduct DC current. As a tech with more than 50 years experience and as an engineer I am sick and tired of the amateur tech advise here.
PostPosted: Mon Feb 18, 2008 4:50 pm
Karyoker
I ordered the HUM unit a couple of days ago, after RLS provided the link for it.
It's $59.
Is a "1/1 isolation transformer" from Radio Shack the equivalent or is it something different?  Any idea of what the Radio Shack product costs?
Lastly, I am still wondering what options, if any, there are as to where the HUM Exterminator can be plugged in?
PostPosted: Wed Feb 20, 2008 7:21 pm
ericlater @ Mon Feb 18, 2008 6:50 pm wrote:
Karyoker
It's $59.
Eric, I plug my laptop power supply into the Ebtech Hum Eliminator and then plug the Ebtech Hum Eliminator into my powerstrip. It eliminated the hum caused by the laptop immediately (just as using a 3 prong to 2 prong adapter did)...only now with the security of knowing the laptop is still grounded by the use of the Ebtech Hum Eliminator.
PostPosted: Thu Feb 21, 2008 7:46 am
RLS,
I do understand that the device will work when connected directly to the laptop; I'm still wondering:
    - will the device eliminate the noise if it is plugged in anywhere else along the circuit? (of course, I'll soon find that out for myself)
    - if it does eliminate the noise used elsewhere, will it still provide the needed grounding?
Karyoker,
I was at Radio Shack yesterday to return the Ground Loop Isolator that didn't help.  The manager knows of no other device that might help with the problem.  Were you referring to Radio Shack when you talked about the shack on regard to the 1/1 Isolatin Transformer?
PostPosted: Thu Feb 21, 2008 9:20 am
Karyoker,
To be honest I am not totally familiar with the ground loop isolator at the shack.  I use an old 1/1 isolation transfomer that I used for transfomerless tv's years ago. If you can run with battery and have no problems then it is a ground loop issue. If you would like pm me I will give you my landline for tech support..
One KJ I know was running a laptop with the ground unhooked with an an adapter A power surge totally fried his computer.
PostPosted: Thu Feb 21, 2008 1:08 pm
Non-Member
The isolator didn't work because the video is the cause not the audio.
PostPosted: Thu Feb 21, 2008 3:02 pm
ericlater @ Thu Feb 21, 2008 9:46 am wrote:
RLS,
Point 1 All you can do is try ...it might ...and it won't harm anything.
Point 2 yes it will still provide the needed grounding (provided of course you are not using any 3 prong to 2 prong adapters along the way)
Let us know if it works by being used elsewhere along the circuit.
I would test it on mine but right now don't feel much like digging into the
clusterf$%# of wires.
(Cable management is one thing I have not yet taken on...I am embarrassed to admit)
PostPosted: Sat Feb 23, 2008 11:46 am
An associate who relies on a 3prong > 2prong adapter to eliminate the hum assures me that since she has everything plugged into a surge suppressor, there is no need to worry about bypassing the ground.
Is there any truth to that?
PostPosted: Sat Feb 23, 2008 12:39 pm
And again that also is a good question, would like to see the answer myself.
Honestly, I am not qualified to answer that...you may not need to worry about surges but I am pretty sure by any use of a 3 prong to 2 prong adapter that which is plugged into that adapter is no longer grounded.
Hopefully there will come along someone who is qualified to answer your question.(and is not just blowing smoke)
To serious a matter to take an unqualified persons answer as truth.
PostPosted: Sat Feb 23, 2008 1:22 pm
Non-Member
For the sake of safety...
Why did the manufacturer put one (ground) on it in the first place?
So everyone could lift it....
Don't mess with it.
You are subject to electrical surges at any time for any reason, especially in a bar.  To protect against them is a very good idea.   We all play during storms, when power lines can come down.    Car wrecks that take out a pole can cause them.   Any drunks ever leave your bar or neighboring ones ?   Coolers in bars have compressors that kick on and off all night long.  These draw a lot of surge to start the motors.    Bar electricity is probably the most unreliable electric you will ever deal with.
PostPosted: Sat Feb 23, 2008 3:44 pm
Side:
Your comment about the "manufacturers'" intentions only begs the question.  I say that because the statement could be made that many products are plugged in
without surge protectors.  Also, the manufacturer doesn't know when a surge protector will be in play.
Everyone:
Just got the Hum eliminator and plugged in into the outlet - THE HUM IS GONE!
PostPosted: Sat Feb 23, 2008 4:00 pm
Non-Member
It is not just to protect you from a surge.  There are other things that can happen in an electrical circuit.
People DIE from electrocution every day.
You don't have the right to suggest that anyone remove or play with the intended safety devices attached to any electrical equipment. :shock:
People that play with fire often times get burnt. :O
There are safer ways to solve the problem.
PostPosted: Sat Feb 23, 2008 4:34 pm
See what I mean?   LOL
Users browsing this forum: No registered users and 3172 guests
