KARAOKE SCENE MAGAZINE ONLINE! - Critique process discussion thread: FOR DISCUSSION, SUGGESTIONS, RECOMMENDATIONS, and WISHES Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Fri Nov 06, 2026 9:56 pm
Post new topic Reply to topic  [ 377 posts ]  Go to page Previous  1 ... 14, 15, 16, 17, 18, 19  Next
PostPosted: Sun Nov 04, 2007 10:19 am
(i do feel some r being honest...)    morgan u fall under the SOME....sorry if i offended you...i didn't mean to....
PostPosted: Sun Nov 04, 2007 10:45 am
Been Liked: 8 times
apology accepted
PostPosted: Sun Nov 04, 2007 11:50 pm
Been Liked: 11 times
Perry,  breath control is going to be a tough area for me, and it's currently the focus of warming up (which includes more controlled inhaling and exhalation as well) Tension, and having no experience using the body as a means to project a singing voice will take sometime to break in..
PostPosted: Sun Nov 04, 2007 11:51 pm
Perry,  breath control is going to be a tough area for me, and it's currently the focus of warming up (which includes more controlled inhaling and exhalation as well) Tension, and having no experience using the body as a means to project a singing voice will take some time to break in..
PostPosted: Tue Nov 06, 2007 6:53 am
Songs: 41
Now I am mostly off pitch at the end of each line.... not bad but not good yet.
I am not a pro by any means, but I here is what I have found.
You must wear headphones when you record a vocal track.
So I am assuming that you are, as do I.
I was having the same problem and found that the volume of the canned music in the headphones was essential for me being able to hear myself.
I have to keep my vocals slightly higher than the music.
If I go too far one way or the other I will get off key myself and it usually happens at the end just like what you are describing.
Don't know if that is what is actually happening to you or not, just a thought...
Imagination is more important than knowledge.
Knowledge is limited.
Imagination encircles the world...
PostPosted: Tue Nov 06, 2007 9:49 am
From my own experience of recording vocals and from reading different articles, it seems that too much bass and volume in the monitor mix can cause vocal pitch problems.  Hearing excessive bass interferes with the ear's ability to hear pitch accurately causing the person to sing flat.
http://www.recordingeq.com/rw/tip01.htm
I also noticed this problem when singing harmonies, playing bass and standing too close to my bass amp on stage.
PostPosted: Tue Nov 06, 2007 11:54 am
What I'm finding personally,  however this is likely just unique to where I am with this, (at this given point) initially I liked headphones, but I feel better with the broader sound spectrum of many speakers when I sing, and more of a surround type setting.   I can't explain why,  I just like more dimensional sound, I believe it in fact HELPS and does not hinder my ability to pitch match yet I don't consider myself a "Front" singer, so I suppose there's a psychological element to this as well
PostPosted: Tue Nov 06, 2007 12:15 pm
I personally do not find bass in a mic to be a hinderance to pitch, neither do I find headphones to be a problem, but more often a help. With headphones I  can hear everything much more clearly.  I do find myself being conscious of diction and listening for pitch as I sing helps me.  I have learned over the years how to sing with emotion and still take care to listen for pitch problems.  When I find that something bothers me on my playback, I will go and do the section over that to me is pitchy.  I can usually hear it when I am singing.  When something grates on my nerves as   I listen, I know it is usually because of pitch.  Headphones make me feel like I am in the middle of the music so whether live music or recorded tracks, I can usually tell if I am on pitch.  I usually don't have to retake because of pitch, but I do record over problems dealing with diction quite often.  I always want my words to be plainly understood.--Mike
PostPosted: Tue Nov 06, 2007 12:32 pm
Ok Kappy, I'm willing to join the numbers to be critiqued... OMG what have I just done?   :?
PostPosted: Tue Nov 06, 2007 5:03 pm
Steven i'm betting the reason u like ur 6 speaker set up is because ur singing without reverb, and that surround vocals r helping u to get that effect somewhat....
i believe when u do start singing with effects u will lose the speakers, at least some anyway....JMO
PostPosted: Tue Nov 06, 2007 5:11 pm
That's a really good point Billy.  When I sing, I am the only voice that isn't being mix'd. eq'd. blended, etc..  Singing with surround speakers appears to drown that out... I'm looking into mixers in MF..  I'll get something.
Assumption being, since it's tougher for me to balance or blend my own vocals into the mix, surrounding myself with the louder spectrum of surround sound gives the illusion I'm blending..
PostPosted: Thu Nov 08, 2007 6:24 pm
Steven,
Have a listen to Jazzy vocal sample; she is back in SS.
PostPosted: Thu Nov 08, 2007 8:31 pm
OK Jian.  I just heard Jazzy posted under "L", so I heard that she's back (roughly about two hours ago).  She's been gone for quite some time.  Glad she's back !
PostPosted: Sun Nov 11, 2007 6:41 am
Been Liked: 25 times
BlueStainedShoes @ Thu Oct 25, 2007 2:44 pm wrote:
But back on subject... IF you make a "whole new area" for "serious singers".... don't you think the same thing will happen as what's happening in C category? I mean, people claim to want true critiques, but you too often don't see it. WHO is going to say "you may sub here, but you may not"??  The C people will all move over there, and it will be the same thing... just in a new area. You can't simply say "this is for serious aspiring vocalists only" and expect the line to be drawn.
Aint gonna happen.  :no:
That's exactly what I see happening, Char... I don't think it would help any more than having a 'C' category helps.
PostPosted: Sun Nov 11, 2007 6:52 am
Steven Kaplan @ Thu Oct 25, 2007 5:28 pm wrote:
With the exception of discussion about the process, look at what those viewing this thread see.. There's no argument, no one-upping, mature folks trying to work something out for the benefit of all, and those ASKING for Critiques getting mature input ?  There's NOTHING objectionable.. Same with any aspect of a Critique category.. There are mods, or silent mods but it's a safe assumption that KS site mods approve of the Critique option... The question is how and where as things evolve,  as I stated, I believe showcase really should've been somewhat more careful with a Critique category,  you cant just throw that word up, and not expect some fall-out..
I don't see anything wrong with having a forum section specifically for critiquing, and I think it would be a nice addition, but I KNOW that it will NOT solve the problems we have with the critiquing process. We may have a 'smooth sailing' atmosphere here NOW, with everyone in agreement about doing and being critiqued, but the first time we get another startlett wannabe who thinks she's god's gift coming in... there will be the same revenge 'critiquing' and garbage we've all seen already because she will THINK she's great, ask for critiques (to stroke her ego) and end up finding out she's not as great as she (or heck, he) thinks.
I guess I can't help thinking that we ALREADY have a system set up for critiquing, and for any well-meaning person to be afraid to use it is just ridiculous. I think a critiquing forum would be a nice addition though.
PostPosted: Sun Nov 11, 2007 8:07 am
Songs: 46
Been Liked: 9 times
Hey Steven....sorry I'm so inconsistent around here. I like to sing, and it seems to take alot of my time. LOL
I have a problem with breath control myself. My only advice is to learn a song really well to know when to breath deeper for a verse that's tricky. I don't think I sing right. I'm not sure that I'm suppose to tense anything to be able to squeal out a high note. I'm so caught up in trying to imitate a singer's sound, I just do anything it takes to try to capture that sound.
Just recently in SS, I did a Lionel Richie song....Truly. I used alot of headvoice I guess. I don't really know the proper terminology for this singing stuff. What I call headvoice is....making sounds that emanate as I'm exhaling, but in a lower volume that barely can be heard while trying to maintain some kind of pitch.
I was having a problem with this when I recorded everything to one track, because I had no way to increase the vocal volume after it was recorded. Therefore, the vocals seemed distant or muffled in my recording.
I recorded this most recent song to separate tracks, and was immediately impressed as to how I could increase the vocal volume before I mixed the tracks together. That also bothers me a bit, because now it showcases every flaw in my vocal. LOL
While singing that song from the start, I was almost in a whisper, but then transitioned to a higher volume as the song progressed, which also required me to apply distance between my mouth and the mic as the vocal volume increased.
After adding some reverb to the "dry" vocal, then compression to lighten any "hotspots", then increased the total vocal volume a tad, I mixed the tracks together and was really surprised of the overall result! I like recording that way now!
The old way of recording to all one track was forcing me to keep my vocal volume loud while singing just so it could be heard in the final product.
But I can't sing with headphones on for some reason? I sang to the separate track while listen to the karaoke song playing through my little pc speakers, although my voice wasn't coming through the pc speakers. So it almost sounded as though I was singing while listening to a transistor radio, and the music volume wasn't enough to bleed over into my vocal track while singing.
But then, since I couldn't tell what I sounded like as the music was playing, I had to wait and listen "after" the song was recorded.
I bet if you recorded a song this way, you could almost whisper the lyrics and get the same end result. I felt that my effort level went waaaaay down while singing and recording that way. The song wasn't perfect still, but I didn't have to scream my lungs out just get the vocal heard. :wink:
PostPosted: Sun Nov 11, 2007 10:25 am
Personally, I'd LOVE to see a critiqueing forum.  My thought being, that way, each person wanting a critique could post their own thread w/the title of what the want critiqued as the topic.  I want to be more involved with this thread, but I get a little lost wading through all the posts as they jump around a bit.  That would make it a little easier, for me, at least, to be effective in critiqueing things I know I would be helpful on.
Also, in regard to your concern about "starlets,' Sebby (which is valid!) once it becomes apparent who they are, it makes it easy to avoid their posts, since I think'd be unlikely they'd spend much time critiqueing others if they just want an ego stroke.
Just my 2 cents. :)
"I hold the key to an open door....will I ever be free...?"
PostPosted: Sun Nov 11, 2007 11:04 am
Songs: 46
Been Liked: 9 times
This is funny! LOL
It sounds like what I just explained to Steven in how I recorded a recent song. LOL
I don't know how sharp or flat that song might sound to anyone, but I know I was more able to hear myself while singing without the loud music.
I'm use to singing with loud music, so it was weird doing it the way I did this time.
And I really don't know how any live performance of mine really sounded to anyone in the bar, so I'm definitely still learning here. LOL
Thanks for that link Don! :handshake:
PostPosted: Sun Nov 11, 2007 11:46 am
My original hopes were for this to become a "critique" thread where discussion regarding the process would take place elsewhere, however I gave up trying to control my threads.. So what I'll do with the help of the mods is this..
I'm going to add a FOR CRITIQUE ONLY, DISCUSSION regarding critique to take place here
It will be as follows.
Users browsing this forum: No registered users and 3286 guests
