KARAOKE SCENE MAGAZINE ONLINE! - sound like a blocked nose Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Thu Nov 05, 2026 7:22 am
Post new topic Reply to topic  [ 24 posts ]  Go to page Previous  1, 2
PostPosted: Sat Apr 14, 2007 8:17 am
http://www.thrivingbabies.com/blog/2006 ... water.html
http://www.pacifichealthcenter.com/updates/62.asp
http://www.natlallergy.com/article.asp? ... 1176567086
What Types Of Nasal Irrigation Products Are Available?
Nasal irrigation has been used for centuries through a wide variety of methods - everything from sniffing salt water from the cupped hand to the use of infant bulb syringes (which we do not recommend as mold can and probably will grow in the bulb). Many more options are available for those serious about obtaining the benefits of regular irrigation. A recent study took a look at three methods of irrigation, and concluded that the "distribution of contrast solution was more uniform using positive-pressure irrigation". This simply means that the irrigation solution is gently propelled into the nose rather than sniffed or poured in. The Nasaline Irrigator is a unique, syringe style delivery system that offers portable, positive-pressure irrigation.
Notice the warning in yellow about your method.
Now I will grant that there are more thorough and complex forms of nasal irrigation, but for a karaoke singer, at least IMHO, sniffing saltwater works just fine for a quick cleanse at home before you head out the door.
PostPosted: Sat Apr 14, 2007 12:17 pm
Now I am not skeptical. 8-)
Yes, I have replaced my syringe twice already (after 4 months doing it), because it was pretty obvious that there was the prospect of some contamination over time. It is only $2.44 for one.
I also rinse the whole apparatus in hot water on a regular basis, as was recommended.
PostPosted: Sat Apr 14, 2007 2:56 pm
any other exercise or thing except .........nasal irrigation ( i am doing it also) .................
cuz i figured out that along with my voice i have also developed a blocked nose accent.......
while singing i leave half the words incomplete ..............but i don't feel that while singing....................when i recorded my voice several times i figured out that i say almost half the word within my nose  ........from the end
PostPosted: Tue Apr 17, 2007 3:16 pm
the nasal irrigation didnt work well ..my one nostril opened up real good and is blowing air like a leaf blower but the other remained totally blocked........
but the tip from exweed farmer really helped.........
which waz
"I don't think the problem is your equipment but rather the way you sing.  Here's a simple test.  Hold you nose closed and sing, loudly.  If there is a noticable difference in your sound other than the muting of certain sounds such as the "n" sound.  You're singing through your nose.  Don't do that.  Get a swimmer's nose clamp at a sporting goods store practice singing with that in place.  It will hurt at first but your sound will be greatly improved in the end."
Users browsing this forum: No registered users and 1981 guests
