KARAOKE SCENE MAGAZINE ONLINE! - Mackie powered mixer question Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Fri Oct 23, 2026 5:19 pm
Post new topic Reply to topic  [ 31 posts ]  Go to page Previous  1, 2
PostPosted: Thu Sep 21, 2006 10:45 am
I usually keep the gain at normal and the volume no higher than unity.
If I need a boost in volume I go for the master main knob.
PostPosted: Thu Sep 21, 2006 11:41 am
Babs @ Thu Sep 21, 2006 10:29 am wrote:
Again - everyone there is using their own equipment. I will be making announcements, doing raffles, singing and later doing karaoke. This is taking place in a medium sized parking lot next to the bar that is my regular gig.
I'm sure the bands will be using their own equipment, but there will be 1 PA to run all the bands.  I guarantee they will not be changing the PA out with every band.  So plugging into the main PA might be an option again.
PostPosted: Thu Sep 21, 2006 11:53 am
Yep,
Pretty lady, YOU NEED TO BAT THOSE BIG BLUES AT THE VENUE HEAD SOUND GUY. :D
No joke, he will also teach you some pro level stuff about your mixer that might otherwise take years to learn.
PostPosted: Thu Sep 21, 2006 9:54 pm
LMAO Unfortunately there is no main PA. This is in the parking lot
of the bar I work at. The bands are the bands that normally come to play at our bar.
The bands will setup their stuff play and leave. Only one band will play at a time.
It is a benefit put together for one of our bartenders who lost their teenage son.
The bartenders and bands are working for free. They only offered to pay me because they need me all day. I didn't even ask how much because I will probably
hand it to her. $10 cover if you want to come and watch me go crazy because it is very unorganized.  LMAO
PostPosted: Thu Sep 21, 2006 11:12 pm
Kellyoke, I have a reverb unit that does the same thing once in a while.      Turn it off for a few seconds and it's back to normal.     I think it has to due with the electricity dropping or surging slightly.   Does it always happen in the same bar?   Try plugging in to a different circuit.   There may be something in that one, that kicks off and on, like a compressor or something.    I asked my music store guy if a reverb unit could work intermittently.   He swore up and down that they either work or they don't.   I proved him wrong. :yes:
PostPosted: Thu Sep 21, 2006 11:26 pm
Wow!.......They are going to rely a lot on you due to setup/teardown times for each band and NO common PA system.....Ouch!
You are going to get lots of mic time and be totally on your own......!
Ok, don't panic.
See if you can determine who is gonna play and when they will be there awaiting their chance to setup.....See if you can enlist one of those sound guys to kinda look over your shoulder at first....Arrainge this ahead of time with them if possible and be there plenty early and get your stuff completely rigged and properly powered and tested by the time they show up...Let him assist you thru the sound test and help you tweek your gain and determine clip points.
Weak vocals?.....No problem........Can you borrow a decent compressor?.....Nope, no time to learn about that, huh?.....So OK, forget the compressor, let's groom our gain structure all the way from the mic thru the board and out to the speakers to get all we can from the vocals.
The only nice thing about working outdoors is you don't have to worry about feedback so much as you do when indoors.....There are no confining walls to reflect sound back into your mics, so that means you can tweek the mics gain higher before feedback can occur.....That's good and it is in your favor this gig.
But you will not be outdoors until just before the gig to actually experience this , so that is yet another reason to show up early.
Start with your speakers disconnected at the mixer outs....unplug them....Turn on your mixer.
-Slide the masters up to unity
-Twist the mic input gain knobs up to unity
-Slide the mic slider up to -6 below unity
-Sing sortof loudly into the mic with it about 2" from your mouth
-Watch the clip light on the mic input as you sing and as you adjust the mic strip input gain twisty till it is flickering pretty steady but never lighted for long when you hit your loudest notes....That is the max gain you can muster on the input for that mic.....Now twist it down just a speck and leave it....Do the same for all mic strips you will use....leave them right where they are.
-Sing the same way again and watch the master output meters.......If they are hitting unity, you are done.....if below unity, then ease the mic slider up slowly till the meters are flirting with unity and then stop and see where the slider is on the scale......If it is above unity, then drop it to unity and place a piece of tape there.....If it is at unity or slightly below, then mark it there with tape.
-Now for the live test.........Reduce all sliders to bottom and plug in your speakers.
-Increase masters to unity
-slowly increase mic slider to tape mark and listen for feedback as you do it....if no howl, then sing with the mic a foot away from your mouth and slowly bring it in closer as you listen for feedback...have hand on masters ready to drop them if feedback starts.....If no feedback, then that mic is set.....do the rest the same way...Mark with tape.
If you do get feedback, then reduce the input gain for that mic enuff to prevent it and try to see if you can increase that mic slider closer to unity before feedback....Mark with tape.
So ok, your mics are now set for max gain before feedback....but you ain't tried them with music playing yet........
So reduce mic sliders to bottom and start the music playing......increase player slider to max level you expect to play it at all night and leave it there while you test each mic......
With music playing at max expected level increase mic slider and listen for feedback....keep increasing it if you can back to the marks you established in last step.....If you can sing and not cause feedback with music playing, then you are done!..........If however the vocals are still too low for the music, then you need to reduce the music slider til you have good mix and accept it....Mark sliders with tape.
If you get feedback thru mics while playing music at loudest expected level, then you have no choice but to reduce mic gain yet farther still, and maybe reduce music too.
Girl, that is how you do it, and that is all you can do..........If after all that it ain't good enuff, then tell them to gather closer to the stage.
Oh, BTW......if all this works well for you, then grab the other sound guys and show them how to do it properly. LMAO
PostPosted: Thu Sep 21, 2006 11:42 pm
Okay now I feel better. I do sort of the same thing when playing new venues, so
it made total sense to me.  I guess I just wasn't confident in my knowledge. I hate
doing things half _ssed. Thank you so much for helping me. :hug:
PostPosted: Fri Sep 22, 2006 1:55 pm
These bands don't use sound guys?  You'e kidding, no main PA?  Like Keith said - ouch.  Everything would go so much quicker between bands setting up & tearing down with a main PA set up that all the bands used.  Even when our band used to play benfit shows like this, there was always some kind of PA set up.  That's odd.
PostPosted: Fri Sep 22, 2006 2:01 pm
Kellyoke @ Thu Sep 21, 2006 6:10 am wrote:
Speaking of Mackie Mixer:  Lonman, this question probably is more up your alley, but appreciate anybody's input.  I've used the CFx12 for over six years now.  Have an older model that I keep at home and use one of the newer cfx12 MKII's at my show.
Question is this:  Over the past six years I have had something occur, maybe 6 or 7 times.  And it has happened on both my old one and the new one.  It happened last night:  everything is going along good; just the right amount of effects and then all of a sudden no effects.  Everything sounds flat.  If you want any effects you really have to over adjust.
I have found that as soon as the singer is through.  I cut the mixer off; pause about 5 secs. and cut it back on and all is well.  It's almost as if it has to rest it self.
As I said though, it's only happened once in a blue moon.  Just curious if you or anyone has had this occur with the Mackie or for that matter any mixer.
Thanks,
Kelly
I've actually never experienced this problem with the Mackie, but I don't rely wholly on the internal effect, just a basic reverb usually, I run an external effects as well.
I did have problems with Behringer board doing what you described.
PostPosted: Fri Sep 22, 2006 3:11 pm
To be perfectly honest I am not familiar with these bands enough to even
know what their set up is. Most of them are blues bands and one is only instrumental.
Most of them run their own sound as far as I know.
PostPosted: Fri Sep 22, 2006 10:28 pm
Usually the event organizer will rent a main PA and sound guy from local sound company...especially benifits....that way it is easier to attrack free talent...They don't have to tote all their crap and set up fully, just plug in an jam.
Users browsing this forum: No registered users and 2272 guests
