KARAOKE SCENE MAGAZINE ONLINE! - Do you compress your own (personal) mic? Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Sun Nov 01, 2026 3:45 pm
Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2
PostPosted: Wed Nov 30, 2011 11:53 am
Jim29 wrote:
mckyj57 wrote:
Jim29 wrote:
I don't compress but would like to buy a compressor that is under $200 to connect to my Allen & Heath ZED 10FX, which doesn't have built-in compression. From what I have read, the best compression option would be to have the microphone connected into the compressor and then into the mixer. I would appreciate suggestions as to what to buy.
I would disagree about that hookup. A good compressor is easily available for less than $200. You would want to use the insert in your mic channel to do the compression. I am not sure that the compressor even has a mic pre-amp, and if it does it isn't as good as the one on the ZED.
I think I'm going to buy this compressor.
ART Pro Channel Tube Mic Preamp and Compressor with EQ
http://www.zzounds.com/item--ART215
I've research other compressors and I'm not very impressed by the reviews. It seems you have to spend around $200 and above to get something decent.
Not sure what your intended use is, just know this is a single channel unit - can only connect to one mic. Designed more for recording and not so much live, but can be used live. If you need more than one mic, then you might look into something else. The dbx 266XL is a good 2 channel unit.
I like the compressor you suggested better and it's less expensive. I'm just going to use it for karaoke. I would like to connect the mic to the compressor and then from the compressor to the mixer so I can have even sounding recordings. All I want to do is maximize the mix so it's as professional sounding as I can make it on a budget.
PostPosted: Wed Nov 30, 2011 12:45 pm
Depending on your mixer, the better hookup option is to connect the compressor via the 'insert' jack on the mic channels. The only reason you'd connect the compressor inline is if the mixer didn't have that jack.
Also a compressor isn't necessarily going to make the overall 'mix' much better, it just keeps the vocals more in an even level when used properly. The overall mix is still going to depend on the input material & how it's all adjusted by the user. Once recorded, depending on the software, there usually are editing tools to normalize/eq/etc the final mix to an even sounding level.
PostPosted: Sat Dec 03, 2011 12:25 pm
I've done some more research and found the FMR RNC 1773 Compressor Unit ($175), which gets excellent reviews:
http://www.amazon.com/FMR-RNC-1773-Compressor-Unit/dp/B0006I935Y/ref=cm_cr_pr_product_top
http://www.fmraudio.com/rnc.htm
This is my top pick at this point. It's small and everyone says it sounds as good as expensive studio compressors.
PostPosted: Sat Dec 03, 2011 1:04 pm
I have 2 of these and they work great. The one thing you have to remember to do is to depress the "Super Nice" button everytime you power it up. Very easy to use and transparent. I bought mine for $125 a couple of years ago.
PostPosted: Sat Dec 03, 2011 6:14 pm
For that price i'd still opt for the dbx. Gives you independent control on each channel rather than one set of controls for both.
PostPosted: Mon Dec 05, 2011 2:30 pm
Just a heads up regarding the DBX 266xs Compressor/Gate which sells for 149.95 at guitarcenter.com.
The DBX 266xs can be purchased for $40 off at Guitar Center since there is a mail-in rebate offer of $30, plus Guitar Center will give another $10 off purchases of $49 or more thru 12/11.
http://www.guitarcenter.com/dbx-266xs-Compressor-Gate-106508708-i1849702.gc?esid=106508708#
Users browsing this forum: No registered users and 1662 guests
