Brian A
Posted: Mon Dec 06, 2010 11:22 pm |
Ingenuity at its finest. What an amazing concept. You just gave me an idea on how to do it. Thanks, C.
_________________ To be fortunate enough to derive an income from a source as fulfilling as karaoke music has got to be as close to heaven as we can get here on earth!
Workmen
Posted: Tue Dec 07, 2010 9:43 am |
Joined: Mon Nov 05, 2007 12:10 pm Posts: 113 Been Liked: 0 time
This is simple! I actually wrote the Songbook program before the Player but a database driven player changed the game. Now the Player Autobuilds the book by searching the song files.
When the book is built all songs have been linked in the book to their song files. So when the remote Songbook shows the songs they are what the Player autobuild action found.
The singer enters in their song(s) into the remote songbook by double-clicking the desired song, then when prompted enters their name and gets an auto-partial-cut printed receipt for each entry. All selections are played back by voice to let even a drunk know the action he/she took.
At the same time the song/singer info is printed for the singer the song is wirelessly relayed to the Player's Hold buffer and will stay there until the KJ moves it into rotation(s) or deletes it. Yes, only a nonconnected wireless router is needed for this since you are using only a wireless network not an internet node.
The singer can tell the KJ which of multiple entries they want to sing on each rotation and can tell him if they want a key, rate or tempo change for that song or can hand him a printed receipt for the song. The KJ can setup these changes with the click of a button. WARNING - Auto-selection assignment by the singer of key, rate and/or tempo change has been tried and discarded!!! If you give the singer the option they will overuse it everytime! Better the KJ be aware of the change so it can be corrected, if needed. They may blame you for their embarrassment and you may loose them and their friends as patrons!
The receipt allows the singer to keep their own history but each book the KJ sets up has its own history which can be recalled at any time and can be sorted by time, artist, title or singer. By double-clicking any song in history it is added to the Hold or Rotation Buffer, whichever is selected. A created Songbook can be copied or modified so each venue can have its own Songbook therefore its own history.
If Hold Bypass is turned on the song goes directly into the Rotation Buffer and if not in KJ mode, auto-play/auto-load on, then the song at the top of the rotation buffer will play automatically and rotate thru all songs in the buffer just like a jukebox. This is true for not only Karaoke songs but MP3s. The 3 MP3 players in the program allow for not only Database controlled MP3 play but manual and auto-filler MP3 play.
Although customer audio or karaoke cds cannot be played as they are not in the database, they can be ripped and added to a temporary database for that nights use only. Saving that temporary database is users option since it may require large amounts of storage and without the discs to support it will be in violation of copyright.
The database has a disc renamer that will rename the external and internal files of a cd+g zip if it is in the current Database of 400,699 records. It will rename all cd+g zips it finds, so to create a ripped book of cd+g zips it is only necessary to:
1. Rip the cds into the same or seperate file folders (preferred). We use Power CD+G Ripper/Burner
2. Make sure to name the files withe the OEM cd name (such as SC8437).
3. The standard cd+g format is CD-Track - Artist - Title and must be used.
4. Point the renamer to the folder that holds all the other folders and start it.
5. Renamer will parse all folders and rename all cd+g zips in them.
Then run autobuild Songbook and program is ready to run.
Remote Songbooks can be added in infinite numbers thruout the venue as desired. The program can be set to come-up in Player mode or Songbook mode so there are not multiple programs to load and maintain, just the one.
The program can be loaded on as many PCs as you want but will only run on a PC with a security dongle. So you can setup backup PCs in advance and be assured they will run just by inserting the security dongle.
BruceFan4Life
Posted: Tue Dec 07, 2010 7:57 pm |
| Super Duper Poster |
Joined: Wed May 18, 2005 10:03 pm Posts: 2674 Location: Jersey Been Liked: 160 times
c. staley @ December 7th 2010, 1:16 am wrote: Brian A @ Tue Dec 07, 2010 3:56 am wrote: c. staley @ Mon Dec 06, 2010 8:19 pm wrote: Brian A @ Tue Dec 07, 2010 1:35 am wrote: Build your own.... Just build a fancy box and bury a computer and touchscreen in it. That's all they've done and it won't cost you a zillion bucks. Great advice C., but for me it's easier said than done. I’m not much of a handyman. I spent long hours with my brother in his garage listening on how to use the tools, none rubbed off on me. I’m not really handy in a sort of productive way. I have neither the patience nor the talent. I’d rather buy than build.  These were made out of modified 2-wheeled dollies by the company I purchased the dollies from. I simply drew out what I wanted and they did the rest. The modification was $100:
NOW THOSE LOOK NICE. I like to try building one of those.
c. staley
Posted: Tue Dec 07, 2010 8:25 pm |
| Extreme Poster |
Joined: Thu Jun 06, 2002 7:26 am Posts: 4839 Location: In your head rent-free Been Liked: 583 times
thanks Bruce,
These are standard dollies that have been cut down (made shorter) and the "necks" that hold the touchscreen monitors on these are a square channel inside a slightly larger one wth a thumbscrew/wingnut thread in between. This makes the necks adjustable.. up or down... Down to fit in my minivan, up at the club... no tools required.
And because the screen is facing the "wheel side," it doesn't "walk" when someone is poking at it.
ripman8
Posted: Wed Dec 08, 2010 10:02 am |
BruceFan4Life @ Tue Dec 07, 2010 9:57 pm wrote: c. staley @ December 7th 2010, 1:16 am wrote: Brian A @ Tue Dec 07, 2010 3:56 am wrote: c. staley @ Mon Dec 06, 2010 8:19 pm wrote: Brian A @ Tue Dec 07, 2010 1:35 am wrote: Build your own.... Just build a fancy box and bury a computer and touchscreen in it. That's all they've done and it won't cost you a zillion bucks. Great advice C., but for me it's easier said than done. I’m not much of a handyman. I spent long hours with my brother in his garage listening on how to use the tools, none rubbed off on me. I’m not really handy in a sort of productive way. I have neither the patience nor the talent. I’d rather buy than build.  These were made out of modified 2-wheeled dollies by the company I purchased the dollies from. I simply drew out what I wanted and they did the rest. The modification was $100:  NOW THOSE LOOK NICE. I like to try building one of those.
Nice!!!!!! Just how sturdy are they? Any wobble at all? Who wants to build me one?
c. staley
Posted: Wed Dec 08, 2010 1:31 pm |
| Extreme Poster |
No wobble at all, solid as a rock.
DannyG2006
Posted: Sun Dec 12, 2010 5:27 pm |
Been playing around with the Compuhost Kiosk and have to say I am impressed. Not only can you step up to a computer terminal or "Song Request Station" as I am calling it, You can access it via the internet using a smartphone or other computer after setting up an account on the main kiosk so one can enter their requests from their seat.
BigJer
Posted: Sun Dec 12, 2010 9:43 pm |
Joined: Fri Aug 28, 2009 10:42 pm Posts: 1064 Been Liked: 92 times
Technology is just amazing these days... Pretty cool solution for the kiosks, but now I'm wondering if you could make them look even sharper by investing in a bit of tin from a local hardware store to build a shell around the innards and then get one of those companies that makes vinyl wraps for cars to make one with your logo on it, attach that to the tin shell and you'd have a really professional looking kiosk.
c. staley
Posted: Sun Dec 12, 2010 10:07 pm |
| Extreme Poster |
BigJer @ Mon Dec 13, 2010 3:43 am wrote: Technology is just amazing these days... Pretty cool solution for the kiosks, but now I'm wondering if you could make them look even sharper by investing in a bit of tin from a local hardware store to build a shell around the innards and then get one of those companies that makes vinyl wraps for cars to make one with your logo on it, attach that to the tin shell and you'd have a really professional looking kiosk.
It's very easy to do.... I've used a black cloth attached to the screen to block the view of the innards...
All very inexpensive.
Users browsing this forum: No registered users and 2311 guests |
