KARAOKE SCENE MAGAZINE ONLINE! - Driverack PA+ Question Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Thu Nov 05, 2026 12:39 am
Post new topic Reply to topic  [ 48 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Fri Sep 11, 2009 9:22 am
All is sounding good.
A friend who sings has asked if I will do sound for her.
She will work from an agency. Different venues.
There would be no possibility of filling the room with pink noise.
How important is that...
PostPosted: Fri Sep 11, 2009 10:07 am
To answer your question first, with the PA+ version you would still have access to the "Fulltime RTA" which would help you make adjustments on the fly. The RTA will help you visually see hot frequencies as well as frequencies that may be lacking.
I guess I'm not sure why there is "no possibility of filling the room with pink noise". I have pinked more rooms than I can keep count of. I go in at a slow time of day, and explain to management and any patrons that may be present what I need to do and that the process usually only takes one or two minutes. In almost five years of using the DRPA I have never been refused, perhaps it's because they understand that just a little bit of inconvenience now helps insure the best possible sound later.
PostPosted: Fri Sep 11, 2009 10:20 am
Thanks London.
I would imagine you go to a more professional venue than I have lined up.
I have a full time day job & would probably get to a venue around 8pm.
Some would be ok, most... "Were not having that in here".
In view of this do you think the PA+ is my best way to go.
PostPosted: Fri Sep 11, 2009 10:56 am
jerry12x @ Fri Sep 11, 2009 1:20 pm wrote:
Thanks London.
What are you using now Jerry? I don't know what I'm comparing right now. To me the addition of a DriveRack was a no brainer. If you don't think you will ever be able to pink the room then the DRPA Plus would be the only way to go when compared to the original DRPA for the reason I stated above. Is it a "must have" ?, of course not. It is hard to beat for all it's features it offers in it's price range. It's a very powerful tool to have in your rack.
PostPosted: Fri Sep 11, 2009 11:13 am
Ok
Mics - 2 x AKG D5 , 1 x EV N/D767a
Zed 14
Emu 0202
Lexicon MPX200
Eurosys 15PM Peavey monitor.
SRM450's daisy chained to a DBX 223XL which feeds a 1k Kam amp running a single EV SB122.
I do not run the Mackies from the crossover.
I have a DBX 166XL which I havnt started using yet.
PostPosted: Fri Sep 11, 2009 11:34 am
Can you play a familiar piece of recorded music? If so, you can do a good job with that. Just use your ears. Practice in your garage or back yard, or just keep doing gigs until it becomes second-nature. Auto-RTAs are neat but people have been doing live sound in venues of all sort since long before they were invented.
Jeff Wheeler, moonlight DJ/KJ
PostPosted: Fri Sep 11, 2009 11:51 am
It is second nature, I did a lot of sound during the 80's & 90's.
Its this narrow low ceiling room that I am on the verge of feedback all the time.
PostPosted: Fri Sep 11, 2009 11:58 am
jerry12x @ Fri Sep 11, 2009 2:13 pm wrote:
Ok
Zed 14
Emu 0202
Lexicon MPX200
Looks like you have a pretty decent setup right now. Adding a DRPA+ certainly isn't a necessity at this point. I'm a little confused though, if I am understanding what you are saying right, you state you daisy chained your SRM450's to a DBX 223XL, then you state you do not run the Mackies from the crossover. Maybe I'm just loosing something in the translation but of course the proper way would be to run both your tops and your bottoms through the crossover.
PostPosted: Fri Sep 11, 2009 12:08 pm
I know. It's having time to try things out.
I used a quick try out which sounded good.
I didn't move on.
PostPosted: Fri Sep 11, 2009 12:26 pm
I didn't move on.
OK Jerry, you know your system works as is, but it may be time to move on. :lol:
I think you will find that running everything thru your crossover will gain you more control. You should be able to get some extra punch out of your bottoms and a little more definition on your uppers resulting in improved clarity to your system. You could actually be losing some frequencies between where your bottoms leave of and your tops take over.
PostPosted: Fri Sep 11, 2009 12:33 pm
Ok I will try & get a rehearsal room & try it.
Looking forward to try the compressor out as well.
I think I might gain volume there.
I get a lot of singers with soft voices. :shock:
I don't know anyone else that uses the AKG D5's.
How are they rated...
PostPosted: Fri Sep 11, 2009 2:00 pm
Compression won't help your gain-before-feedback; quite the opposite. It will keep you from being surprised by screamers, though; and it's an immensely useful effect.
PostPosted: Fri Sep 11, 2009 2:55 pm
Looks like I am going to have to flash a sign.
SING LOUDER.
Is there nothing that will help me ?
I know... Get a bigger venue.
PostPosted: Mon Sep 21, 2009 11:18 pm
hi folks,
can somebody explain the meaning of fulltime RTA as how it is supposed to be an alternative to suing pink noise? I couldn't find a DRPA+ manual so I couldn't figure it out. From what I could gather in one of the posts, that it still uses the RTA Mic but not to dtect pink nosie? :oops:
Would gretly appreciate a further discussion on this to help me decide if it's what I need to add to my gear. :)
PostPosted: Tue Sep 22, 2009 1:02 am
"Fulltime" RTA means exactly what it sounds like it means. The RTA is visible and accessible to the user during a performance. Meaning the RTA can read the room and be used to adjust any hot or attenuated frequencies live. The original DRPA's RTA function was only visible and accessible during set up.
You are correct in that it still uses the RTA Mic but instead of reading pink noise it would be reading the program material in the room in real time. During setup it would still use pink noise.
PostPosted: Tue Sep 22, 2009 1:23 am
o i see, thanks londonlive. so this means that we'll have to leave the RTA Mic in place during the show? which according to some posts in is placed 10-20 ft away from the 2 speakers?
secondly, I've also seen a reference to a USB interface, does this mean all the wizards and the manual calibration (EQ, Compressors, cross over,.etc) could now be controlled by a PC? Wow! this is good stuff! :P
PostPosted: Tue Sep 22, 2009 2:48 pm
Driveback Questions.
Are you using the driveback to replace other pieces or are you using it with the other pieces?
Is the driveback better than using separate units? Why?
Explain the chain hookup.
Mixer, Driveback, amplifier. That's it?
What pieces have you totally eliminated. :angel:
PostPosted: Tue Sep 22, 2009 3:11 pm
I still have an "oh (@$%&#!)" equalizer in my signal chain. I have speaker tuning in the DSP (DRPA/DCX2496 depending on which rig) and then if I need to tweak for the room or fight feedback, I reach for the separate equalizer.
PostPosted: Tue Sep 22, 2009 5:34 pm
i currently have only an FBQ3102 EQ between my mixer and the powered speakers. was starting to hunt around for a compressor/limiter to help me protect my speakers when people scream into the mic, and was also considering an Anti Feedback unit because sometimes the venue really doesn't allow me to place my speakers in the 'right' place. That's when I saw the DRPA+ and thought this could solve what I need and also replace my Behringer EQ. At least that was what i was thinking :oops:
PostPosted: Tue Sep 22, 2009 10:22 pm
:oops: :oops:
managed to download the manual, now I understand that the USB is for firmware upgrade only :( but still sounds like a good investment :)
Users browsing this forum: KarenB and 1993 guests
