KARAOKE SCENE MAGAZINE ONLINE! - Bridged Mono Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Thu Nov 05, 2026 9:56 am
Post new topic Reply to topic  [ 35 posts ]  Go to page Previous  1, 2
 Post subject: Re: Bridged Mono
PostPosted: Wed Mar 25, 2009 2:59 am
LondonLive @ Tue Mar 24, 2009 7:04 pm wrote:
gator @ Tue Mar 24, 2009 7:52 pm wrote:
Thanks for the info can you tell me the configuration for hooking a Yamaha MG124 CX to this and if I could plug my laptop into it to play my music??
Just run two XLR cables (mic cables) from the Yamaha's XLR output jacks to the Behringers XLR input jacks. You could hook your laptop up to your Yamaha by using a simple cable adapter from the laptops headphone jack to either of the Yamaha's stereo RCA inputs (channels 9/10 or 11/12). That would be the easiest way. A better way might be to use a USB interface and bypass your laptops soundcard entirely.
Don`t Mic Cables have 2 different ends on them?
Gator
PostPosted: Wed Mar 25, 2009 3:04 am
Gator
PostPosted: Wed Mar 25, 2009 6:07 am
If you mean one male and one female then yes Mic cables have two different ends. You can get adapter cables that have XLR on one end (either male or female) and T/R/S 1/4" on the other if that's what you need. There are also just adapters that would convert a regular XLR to 1/4" T/R/S. Be careful if you go the second route as a vast majority of these adapters are XLR to just a T/S on the 1/4" end. I usually just make my own cables to suite my applications, it makes life much easier for me.
PostPosted: Wed Mar 25, 2009 1:05 pm
I thought the end of a mic cable xlr that plugs into the mic was different then the end that plugs into the mixer? But from what I understood you to say was that I could just use a regular mic. cable to go from amp. to mixer correct?
Gator
PostPosted: Wed Mar 25, 2009 1:07 pm
Yes you can go from the mixer to amp with a standard mic cable with XLR ends on each end.
PostPosted: Wed Mar 25, 2009 1:38 pm
Thanks for the reply Lonman but I have a question someone stated that I couldn`t use a speakon to 1/4" adapter with this amp.? Do you know of an adapter of this type I could use or would I have to buy the whole cable? I`m sorry for all the questions but I`m considering buying these 2 pieces and I want to be informed as much as I can. Thanks again...
Gator
PostPosted: Wed Mar 25, 2009 2:07 pm
Like said if you do not know how to rewire the Speakon end for bridge mode, then it will be a whole lot easier just using the binding posts with the banana plug to 1/4" adapter.
PostPosted: Wed Mar 25, 2009 2:13 pm
Then just daisey chain off of speaker #1. Could I run more than 2 speakers with this daisey chain config?
Gator
PostPosted: Wed Mar 25, 2009 2:17 pm
In a bridge mode you can ONLY run 2 8 ohm speakers maximum - as this will drop the ohms to 4 ohms which is the maximum load for the amp in bridge mode.
I wouldn't daisy chain the speakers, just get 2 of the adapters & plug them in piggy back to the amp then run to each speaker individually from the amp. Unless you have a distance factor, I prefer not to daisy chain.
Now if you know how to rewire for a series/parallel connection, you could hook more speakers up, but a lot more hassle than sometimes worth.
PostPosted: Wed Mar 25, 2009 2:25 pm
How can I piggy back those 2 adapters from looking at the pic. it doesn`t seem possible?
Gator
PostPosted: Wed Mar 25, 2009 2:27 pm
Yes one plugs into the amp via the banana plug, the other plugs into the back of the banana plug itself that is in the amp. I do it all the time.
PostPosted: Wed Mar 25, 2009 2:35 pm
Lonman @ Tue Mar 24, 2009 5:47 pm wrote:
https://www.carvinguitars.com/products/single.php?product=AD42
It seems like in this picture the 1/4" cable is in the way and would prevent plugging into the back of it, if that is what you are talking about. Thanks for your patience and help....
Gator
PostPosted: Wed Mar 25, 2009 3:23 pm
The PLUG itself will plug into the other plug. When you plug it into the amp via the binding posts, the very top of the plug is another set of holes that another banana plug will plug into. Don't look at the cable or the 1/4" end. The plug will plug into the top of the plug.
PostPosted: Wed Mar 25, 2009 3:31 pm
Thanks for all your help...
Gator
PostPosted: Wed Mar 25, 2009 7:02 pm
The name ain't someone, the name is London and I thought I explained pretty well why you could not do that. I'm blowing this pop stand.
Users browsing this forum: No registered users and 2395 guests
