KARAOKE SCENE MAGAZINE ONLINE! - Sax N Dotty Software Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Thu Nov 05, 2026 4:04 pm
Post new topic Reply to topic  [ 51 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: Sax N Dotty Software
PostPosted: Sat Feb 21, 2009 4:30 am
Anybody worked out how to move the scroller on the performers screen on the new verion of show hoster ,you can click top or bottom but i would like to either have it in the middle or about 3/4 of the way up?
PostPosted: Mon Feb 23, 2009 5:09 pm
Hey guys. I still cannot view the lyrics. Any suggestions?
PostPosted: Mon Feb 23, 2009 5:23 pm
Have you downloaded and installed the lyrics plugin --> MP3&G plugin --> http://www.winamp.com/plugins/details/100775
PostPosted: Tue Feb 24, 2009 10:20 am
I have Sax N Dotty, Winamp, MP3+g Plugin, and the Pacemaker Plugin. All of these downloads were taken from the Sax N Dotty website.
PostPosted: Tue Feb 24, 2009 10:29 am
Does everything work now?
PostPosted: Tue Feb 24, 2009 11:09 am
I use older versions of Winamp, the cdg plugin and the pacemaker plugin... so to each their own!
PostPosted: Tue Feb 24, 2009 3:46 pm
After you start playing a song in Sax N Dotty there should be an icon for the mp3&g plugin showing down in the taskbar (the actual window may be hiding behind the Sax N Dotty window) if it is there, click on it (this will bring it to the forefront) then right click on the lyrics window and select "always on top"
PostPosted: Tue Feb 24, 2009 7:01 pm
No. It still will not show the lyrics.
PostPosted: Tue Feb 24, 2009 7:30 pm
Then it more than likely is that you do not have a valid karaoke file (an mp3 file and a cdg file) this would be the case if you have been trying to rip karaoke files off of a karaoke disc using Audiograbber and your cd drive is not a cdg capable drive.
I would now try using the ripping software suggested by DannyG2006 earlier in this thread.
PostPosted: Wed Feb 25, 2009 4:04 am
[quote="Michaelangelo1 @ Fri Feb 20, 2009 1:48 pm"]It is possible that the drive you are ripping from is not supported by the ripping software. I had the same problem with a Audiograbber.
However, when I switched to Karaoke File Converter and Rip N Zip I didn't have a problem (note that you can try both for a limited time before you buy).
Some software is more versatile with a wider variety of drives than others.[/quote]
This might work for you as well. see www.kjamp.com.
Like I mentioned previously, I had the exact same problem ( but with different hosting software), and this is how I fixed it.
PostPosted: Wed Feb 25, 2009 5:15 am
www.kjtools.com for cdgrip
www.powerkaraoke.com for CDG burner.
Both work with more than is listed than Goldenhawk's list of compatable drives.
heck both work with a stock Acer drive in my laptop. If it will work with that then it should work with other drives just as well.
According to Powerkaraoke, the MAtsui drives are the only ones that their software won't work with. (forgive the spelling on the drive brand).
PostPosted: Wed Feb 25, 2009 9:08 am
Let's keep this simple for now
Go to the following website an download the cheapest track you can find. It will come as a Zip file, which is what S&D uses. You may want to duplicate the file*. Then put the zip file(s) in a folder.
https://www.buykaraokedownloads.com/
You then import the folder you created into S&D. It should work. If it doesn't, THEN you know you have a problem with you installation.
* The duplicating of the file was recommended because the version of S&D I have often doesn't work if I am trying to import just one file. SO... I do as I suggested to you duplicate it and I then delete the extra file when I am done!
PostPosted: Thu Feb 26, 2009 4:39 am
[/quote] Re: Sax N Dotty Software
Posted: Sat Feb 21, 2009 12:30 pm
Anybody worked out how to move the scroller on the performers screen on the new verion of show hoster ,you can click top or bottom but i would like to either have it in the middle or about 3/4 of the way up? [quote]
Zonerc.
Move your mouse over onto the 2nd screen and over the scroller bar, right click and hold then "drag" the bar to where you want.
But why would you want it in the middle of the screen. Right in the middle of the lyrics ??? I'm confused
PostPosted: Thu Feb 26, 2009 4:46 am
hi there mr.fahrenheit
i would want it in the middle of the lyrics ,but mine dont show when a songs playing anyway the cdg screen comes over it,its for when nothing is playing so want it where is can be seen well on a projector screen.
thanks on advice will give it a try tomorrow night at the gig.
PostPosted: Thu Feb 26, 2009 4:58 am
Hi again Zonerc,
The way I use it is as follows.
I have the scroller bar at the bottom of the screen.
I reduce/move the lyrics screen (when it appears) so it's filling the screen above the bar but not OVER the top of it.
This way the singers can see whose next as soon as the previous song starts to play so it gives them plenty of time to prepare.
You need to make sure that all the correct boxes are ticked in "Options" for it to work automatically as described
PostPosted: Thu Feb 26, 2009 5:05 am
the main prob i have is how the landlord has the projector set up for his tv i loose a small amout from the screen top and bottom and no matter how ive pulled the performers screen about the only was i get the scroller to show properly was to end up with a gap at the top on the normal portable tv,but might try what you sugest with the 2 screens and if not maybe what you said on the first post will work .
PostPosted: Thu Feb 26, 2009 5:11 am
just opened s&d and tried to pull scroller down with the mouse but it does nothing happens it just carries on scrolling come off the scroller and it moves the screen you would expect and i knew.
PostPosted: Thu Feb 26, 2009 5:42 am
I don't know then.
On mine I can drag the bar even over onto the first screen as I can with lyrics screen.
Maybe something to do with the way 2nd screen is set up which I don't fully understand.
PostPosted: Thu Feb 26, 2009 5:53 am
just wondering if ive misunderstood ,do you mean you drag the scroller bar or your dragging the ole performers screen,i can move all the screen same as i can move the cdg screen but cant move the scroller down the performers screen .
PostPosted: Thu Feb 26, 2009 5:57 am
Users browsing this forum: No registered users and 2252 guests
