KARAOKE SCENE MAGAZINE ONLINE! - Power Watts And Square Footage Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Thu Nov 05, 2026 7:15 pm
Post new topic Reply to topic  [ 28 posts ]  Go to page Previous  1, 2
PostPosted: Tue Jan 20, 2009 11:35 pm
This could be a whole new standard in the audio business. It would be like "THX Approved" only it would be "CC Approved". It will let prospective buyer's know that the product they are buying has that little extra needed to get the mix out. Maybe there should be a button on the amp, the "CC" button. You could visually scan the patrons in the room and push the button when needed.(of course deluxe models would automatically do this for you) Quick, someone get the copyright. I wonder if we will see "CC" also being used on the license for the establishment in the future, you know like "Capacity 350" "CC Capacity 300". Ok, my brain hurts now.
PostPosted: Wed Jan 21, 2009 12:47 pm
There are higher-end amps where you can pick the amperage output. Like a 1000 watt/8 Ohm/2 channel amp that is also selectable at 500 watts and 250 watts. Makes it so you can have one amp for many speaker configurations for different venues. Not that far off from the CC selector!!
PostPosted: Wed Jan 21, 2009 3:15 pm
Did anybody mention distributed sound?
A speaker usually rated at 136dB SPL is usually at a specific frequency typically around the 40 Hertz range at 1 meter, but the sound energy dissipates inversely as the square of the distance. Higher frequencies aren't anywhere near that SPL at that range. Between standing waves and EQ'ing it's all a matter of what flavour your sonic soup is.
Remember, the Holy Grail of the FOH guy is that every seat in the house hears what he hears. You can't change the environment but you can change the way your sound behaves in that environment.
PostPosted: Wed Jan 21, 2009 3:26 pm
You are correct, I have a Yamaha EMX5000-12 that has that feature. It can select between 500, 300 or 100 watts per side. I seldom get the occasion to use it any more but it is a very versatile mixer.
PostPosted: Wed Jan 21, 2009 3:53 pm
LondonLive @ Tue Jan 20, 2009 4:32 pm wrote:
I already run 4,800 watts and I'm going to be doing a room in about three weeks that has me concerned. I expect roughly four hundred people and at this point I don't know the room lay out (I plan to investigate in the very near future). I'm seriously considering bringing in an additional 1,800 watt's for this gig (2 Yorkville U15P's). Power is the key to good sound, without power you could have the best of everything else and you are still going to be doomed to a night of frustration. Nothing sounds worse than a system that is trying to do more than it is capable of doing and nothing sounds better or is easier to run than a system with headroom to spare.
Whoah.......So you expect to run 6,600 watts? Where u playin dude....Madison Square Garden???
PostPosted: Wed Jan 21, 2009 4:52 pm
More power equates to full/clean sound at regular listening levels without having to really push the volume up to extremes. That wattage is not unreasonable for a 400+ person venue. I run 3600 watts for my 200 cap club.
PostPosted: Wed Jan 21, 2009 5:04 pm
There is no substitute for headroom. :banger: Actually my main concern is coverage, that's why I need to get a look at the room.
PostPosted: Wed Jan 21, 2009 5:55 pm
In regard to the size (sq ft) of a room, wouldn't the shape be more important - square vs long. Compare, say, a 100'x100' rm vs a 50' (wide) 200' (long) room (both 10000 sq ft). Is there a difference?
Users browsing this forum: No registered users and 2334 guests
