KARAOKE SCENE MAGAZINE ONLINE! - Powered Tops & Bottoms volume Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Fri Nov 06, 2026 10:47 am
Post new topic Reply to topic  [ 28 posts ]  Go to page Previous  1, 2
PostPosted: Wed Feb 27, 2008 5:27 pm
If you have seperate Subs Mids and Tops You need a 3 way crossover.
PostPosted: Wed Feb 27, 2008 5:31 pm
sidewinder @ 28th February 2008, 9:21 am wrote:
Do you really need the crossover if all the speakers have separate amps?   Aren't they crossed over internally?
!5 years of experience, and you ask this.
PostPosted: Wed Feb 27, 2008 5:52 pm
Non-Member
Well are they internally crossed over or not?
If they are, why do you need an external crossover too?
PostPosted: Wed Feb 27, 2008 8:19 pm
Yes they are crossed over internally for their own cabinet.  The sub probably has it own high cut off point as well.  When running them together, unless you get the crossover point between the sub & you top cabs just right, the top cabs are going to be trying to reproduce what the sub is supposed to be taking care of.  Also if the sub isn't at the correct point, it could be trying to reproduce frequencies that the tops are supposed to be handling.  An external crossover will take care of this PLUS give the added benefit of being able to control the balance between the subs & the tops - which is what you asked for in the first place.
PostPosted: Wed Feb 27, 2008 8:22 pm
Well not necessarily a 3 way would be necessary.  His tops are already crossedover internally.  An external 2 way would be all that is needed.  Crossover point approx 80-120hz, everything below that point goes to the sub, everything above goes to the tops & are divided internally to separate the mid & high.
PostPosted: Wed Feb 27, 2008 8:23 pm
Internally crossed over to be used as stand alone units.  Add a sub - even one with a built in crossover, then the whole system can gain much benefit froman external unit.
PostPosted: Fri Feb 29, 2008 11:36 pm
I had a another thought on this topic. Keep in mind my speakers were all made by the same company and designed to work with each other. As a matter of fact it even states in the manuals that no cross over is required. I know there seems to be a concern of balancing the tops and the bottoms for audio level from the mixer. So that got me thinking about the technique known as "Auxiliary fed subs" so of course, seeing how I seldom sleep anyway, I went down and reconfigured the gear to  accommodate, it really didn't take long. I fired everything up and ran a few tests. Well in deed it works beautifully and an added benefit is that as the Aux used for subs is only carrying low frequencies so it can be dialed in for that purpose. Anyway, just another thought on the subject. It's the old "if theirs a will, theirs a way" thing. I had heard and read about the practice quite awhile ago, but I've been running through a driverack so I had never give it much thought. Has anyone else ever tried this?
PostPosted: Sat Mar 01, 2008 7:49 am
I assume by that you take a post-fader aux and set it to some level for each channel, and use that to feed the subs. Subs almost being mono by nature....and you may run mono anyway.
That means you need an EQ channel for it. I wouldn't save a rack space in that case -- or would I? No, I wouldn't, because I use an EQ channel to eq the FX feed and roll off the low frequencies, and so my EQ is full even though I run mono.
Users browsing this forum: No registered users and 3181 guests
