KARAOKE SCENE MAGAZINE ONLINE! - New preamp...returning back to store! hum Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Fri Nov 06, 2026 6:27 pm
Post new topic Reply to topic  [ 28 posts ]  Go to page Previous  1, 2
PostPosted: Mon Aug 20, 2007 3:45 pm
He was feeding his outboard pre directly into his mixer pre via 1/4"-XLR cable
He needs to come out of the outboard pre and into the board at line level.
PostPosted: Mon Aug 20, 2007 5:11 pm
If he is coming out of the Servo Balanced 1/4" of the C Valve, and into an XLR mic input on his yahmee, it should work like downtown. The output of the C Valve according to the diagram on page 14 of his owners manual, is servo for low or high Z. They show a diagram on page 14 with this setup. Like karyoker said..it's ground trouble most likely. Try it in a different board, with a different TRS~XLR cable, and see what happens is my first suggestion at this point. Let us know how you make out Jim. :oh yeah:
PostPosted: Mon Aug 20, 2007 6:33 pm
I'll look at the pin assignments, and let yall know how he made up my cable. I can use a VOM if I have to. Thanks for all help so far. Yall are WAAAAAYY above my head on this stuff. I can test cable, and re solder, but thats about where my knowledge base ends on this one!! :shock:  I'll post what I find in the morning before I go to work.
Jim
PostPosted: Mon Aug 20, 2007 7:17 pm
karaoke for food..... @ Mon Aug 20, 2007 3:33 pm wrote:
Lonman Wrote:
Try a cable with XLR on both ends.
he can't, the Samson C Valve, has only a 1/4" TRS "Tip/Ring/Sleeve output. No need to adapt it to make matters worse.
JimW. Let us know what's going on, and for heaven sakes, if you want to live to be a ripe old age Don't Lift Any Grounds Or Defeat Any
Yes I realized that after looking closer, we were actually talking about another unit before he went this route - that was the one I was thinking of.
Agree strongly about the no ground lifts.
PostPosted: Tue Aug 21, 2007 2:42 am
Yes, I had asked Lon for a recommendation for getting a "pre", and then didn't follow his advice! I should have! I found the C Valve locally for just a few more bucks than the ART, and bought it instead.
I called the local dealer and he said I had 10 days to return it if I'm not satisfied, so this gives me a little headroom to troubleshoot. :thinkin:
I'm gathering my meter and clip on leads to do some checking on the patch cable first. I'll post back later this morning with my findings.
Thanks, Jim.
PostPosted: Tue Aug 21, 2007 10:09 am
Probelem solved.  Finally found a block diagram for that mixer. It has a mic/line switch on the mic channels. It needs to be in line position with the pre plugged in or you will get hum. I did have him switch to the 1/4" input it has a 10db attenuator pad and I wasnt sure if the switch worked with the xlr input or not.
PostPosted: Wed Aug 22, 2007 6:11 am
Thanks for the help Karyoker :D , and everybody here. I appreciate the help so much. Now that the hum issue is resolved, I can move on to "how to use a pre"...!
Jim
PostPosted: Wed Aug 22, 2007 6:41 am
Yep, like I said, you need line level coming into your mixer, and you can't then input that into your mixer XLR, it's gotta go in at either an insert or a line input.
Glad you found it!
Users browsing this forum: No registered users and 2325 guests
