KARAOKE SCENE MAGAZINE ONLINE! - How about using an Ipod for music input? Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Tue Nov 03, 2026 10:37 pm
PostPosted: Sun Mar 12, 2006 4:01 pm
I am getting ready to do a private party, and the host told me he had some songs on his Ipod he would like to use.
I see no problem, just need an adapter from the headset jack to convert to either 1/4 or rca type inputs to my Peavey 680 powered amp.
Since I have not connected one before, I was curious and was hoping someone could give suggestions on what or what not to do.  Most of my inputs are line-level inputs, and from what it looks like, this will be using an amplified signal from the headset jack.  Recommendations???
PostPosted: Thu Mar 16, 2006 5:50 pm
I use iPod for filler music between singing and it works great. I bought one of the 1/4" to micro plug cable (stereo and customer made I believe) from ebay and it's been great. Let me check tonight to be sure that the cable is what I said it is and let you know. I have it connected to one of the stereo inputs, not tape input, of Mackie mixer and it has been working fine. Good luck.
Seize the day and SING!!!
PostPosted: Fri Mar 17, 2006 2:00 am
iPod out is Hot (Gain Heavy).
I used my wife's as a test for a possible back up solution. I works you just need a mixer input with gain control, so it doesn't distort.
PostPosted: Fri Mar 17, 2006 7:54 am
I use a Creative Labs Nomad for my filler music. Just get a 1/8" to RCA adapter, then plug the RCAs into one of the stereo channels of your mixer OR the STER IN channel of your mixer. If the iPOD comes out gain heavy, pump the volume on the iPod down to like 50% to get more gain and volume control from the mixer for that particular channel!!
PostPosted: Fri Mar 17, 2006 10:39 am
I know several kj's that use i-pods for fill with no probs, actually know 1 dj that uses 2 i-pods & a dj mixer for his show.
PostPosted: Fri Mar 17, 2006 1:02 pm
http://www.musiciansfriend.com/product/ ... sku=808462
PostPosted: Fri Mar 17, 2006 2:01 pm
JAMKARAOKE @ Fri Mar 17, 2006 1:02 pm wrote:
http://www.musiciansfriend.com/product/Hi/Fi/A/V/Equipment/Portable/Audio?sku=808462
Yep figured it was going to happen someday!
PostPosted: Fri Mar 17, 2006 2:08 pm
Thanks to all for the replies.  Looks like I should be fine (after I get the adapter cable)
Interesting mixer......
PostPosted: Mon Mar 20, 2006 1:44 pm
Just to confirm, I checked the cable and it had mini plug on one side for the iPod, other side was dual 1/4" which I plugged in to my stereo input of Mackie. It was a custom cable I bought on ebay. Good luck with it.
Users browsing this forum: No registered users and 2068 guests
