KARAOKE SCENE MAGAZINE ONLINE! - I need "Karaoke for idiots help" please Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Tue Nov 03, 2026 12:03 am
Post new topic Reply to topic  [ 31 posts ]  Go to page Previous  1, 2
PostPosted: Thu Jan 05, 2006 10:08 am
Steven Kaplan @ Thu Jan 05, 2006 9:46 am wrote:
That's a good article Lonman,  I was over at Rane, reading about power amp clipping, and how/why it effects speakers. This article get's into it too. I don't follow things such as harmonic distortion and massive wave clipping or aspect's of audio physics.. So I'm trying to figure this stuff out..
http://www.rane.com/note128.html
Think of it this way - in terms of headroom.  You are the speaker.  You are in a low ceiling room (low powered amp).  You are sitting comfortably (normal volume) but now you stand up (volume increase) & hit your head (clipping ie distortion) OUCH (blown speaker).
Take your same self in a high ceiling room (power amp higher than rated power), you are sitting comfortably but now stand up (volume increase), you don't hit your head & can still stretch your arms to boot - headroom!
:D
PostPosted: Thu Jan 05, 2006 10:17 am
Been Liked: 11 times
That's interesting,  thanks !  It's strange that so many of us have been using amp's and speaker's most of our lives, yet really know very little about the technical aspect's,  how they work together, or DON'T work together... Speaker efficiency was also a phrase (I'd only heard) prior to this week when I started reading about it.  I had no idea how important  this stuff is to know about..
PostPosted: Thu Jan 05, 2006 10:22 am
LMAO
Best post of the day!!!And makes more sense than anything....I'm gonna start wearing my hard hat to gigs LMAO  LOL
PostPosted: Thu Jan 05, 2006 10:29 am
Clipping means the Sine wave is just clipped, causing a harsh distortion ?  Depending on the degree of clipping it's a common distortion ?   Hey Karyoker, why do some of us folks like tube amp distortion ?  How is that smoother than tranny which is harsh in comparison ?
PostPosted: Thu Jan 05, 2006 10:59 am
It's true an underpowered amp won't blow a speaker, however a small amp will tend to be pushed to higher gain levels & go into clipping faster & the distortion CAN blow the speaker.  A 10 watt amp can kill a 1000 watt speaker - distortion is distortion no matter what wattages & distortion WILL kill a speaker.
Thats what I meant, if a speaker is killed, it might as well be blown, you aren't going to be able to use it again to produce decent music. I guess I just like to keep replies down to 50 words or less. As usual, [glow=red]Loneman[/glow], great article.
PostPosted: Thu Jan 05, 2006 11:00 am
As someone who used a square wave to tune the klystron (hi freq amps) chain in 3 megawatt radars this clown doesnt have a clue what causes clipping or what harmonics are..There is nothing complicated about either one.. Clipping occurs when the amplified peak ac component on the plate (tube) or collecter exceeds the dc voltage  of the power supply - the voltage drop across the plate or collector resistor...Since the linear portion of most amps is -3db on the low and high side in the over all gain structure they shlould be run well into this region . Whether recording or setting gains I like to run -6db on the sliders and even mains out.. The rapid transition from flat or dc to ac produces a high frequency component A scope probe or any amp can be tuned with a square wave by monitoring the ouput and tuning for no roll off on the leading or trailing edge of the square It is essentially grtting the broadest bandwidth from input to out..
Steve the old tuber has tungsten elements grid, accelerator and suppressor that vibrate resonantly with certain frequencys of the audio component. Then these added freqs produce even harmonics which interleave with the originals and produce a vibrato and richness that cant be duplicated digitally...
PostPosted: Thu Jan 05, 2006 11:15 am
Thank's Karyoker.  I understood part of the explanation LOL.  I guess that's why some of you are tech's, and I just try to visualize what's happening
Would you hate me in the morning, if I told you I'm too much of a bimbo to have a clue as to what the above paragraph means ? :D
PostPosted: Thu Jan 05, 2006 11:43 am
Would you hate me in the morning, if I told you I'm too much of a bimbo to have a clue as to what the above paragraph means ? Very Happy
I dont think I undrstand it any more either LMAO  LOL
They have over complicated it too much for this old simple mind...
PostPosted: Thu Jan 05, 2006 12:01 pm
I printed it out,  and I'm going to have it put on the back of a T shirt..  That way 2006 I'll get lucky !
In not to long a time Karyoker, I'll be able to go to the community college's free.. At that time, I'll take an electronic's course, yet I doubt any of it will sink in. I just don't have an aptitude for some of that stuff... Like the fundamental and quantitative aspect's of chemistry, you just have to know them long enough to pass the damn course.
PostPosted: Thu Jan 05, 2006 12:10 pm
I think the great sound engineer Beavis said it best in his layman's explination to Butthead:
"The angle of the dangle is inversely proportional to the heat of the beat."
That's all you really need to know!!
PostPosted: Thu Jan 05, 2006 12:38 pm
LMAO And directly proportional to the dosage of viagra.... LOL
Users browsing this forum: No registered users and 2363 guests
