KARAOKE SCENE MAGAZINE ONLINE! - Best Way to Disk To Disk Copy CD+G for backups Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Mon Nov 02, 2026 1:55 pm
Post new topic Reply to topic  [ 32 posts ]  Go to page Previous  1, 2
PostPosted: Mon Nov 21, 2005 8:11 pm
thought i'd jump in on this topic as i just purchased a plextor 716A (suppose to be able to copy and burn CD+G)  anyone used that particular model and with what software?  i am considering the power karaoke mentioned above, but i have been told that NERO will worrk just as well.  your thoughts?
PostPosted: Tue Nov 22, 2005 10:08 am
Can't comment on the Plextor drive since I use Yamaha but I don't see why it should not work with all the software mentioned above. I am pretty sure that 716A is one of the models supported for CD+G burning.
As for Power CD+G versus Nero. I looked at Nero for a few minutes and decided against it. First, Power CD+G is very easy to use. Nero took me a few minutes to figure out what I needed to do. Also, Power has access to database so it looks up the name of each title. Of course, it's not complete but I am finding that 1 out of 3 discs are in the database. With the new copy feature, it's a snap coping a disc using two drives.
Hope this helps.
Seize the day and SING!!!
PostPosted: Tue Nov 22, 2005 10:27 am
www.mtu.com  microstudio is an excellent software and it works great with your plextor burner
FlipSide Karaoke
Scott
PostPosted: Tue Nov 22, 2005 1:19 pm
i looked at MTU briefly, but does it also have an authoring tool?  that's one of the things i think i really like about power CD+G. i can go in and fix incorrect text or even author my own discs.  thanks for the info, y'all
PostPosted: Tue Nov 22, 2005 3:06 pm
Yes, Karaoke Home Producer Software
Discover how easy you can add lyrics to your songs to play in karaoke player machines. You can quickly create karaoke cdg songs with sweep highlighting like a professional, or even redo songs you buy that have out-of-sync lyrics.
http://www.mtu.com/basics/karaoke-home-producer.htm
PostPosted: Tue Nov 22, 2005 4:56 pm
you can also use a freeware program called "editcdg" or "edit cd+g" or something similar. I have it on my home pc, and used it to correct blips when they occur,
I personally like "Karaoke Builder Studio" and have used it to build three home tracks! But it's expensive!
PostPosted: Wed Nov 23, 2005 6:15 pm
hadn't heard of that one and really if you want to do the best show for your singers, cost isn't really a factor.  i  just want to make sure i buy the best program for my needs.  again thanks for all the info.  i think i'm gonna like it here!
PostPosted: Thu Nov 24, 2005 1:06 am
Been Liked: 8 times
The are also PowerKaraoke and PowerKaraoke Plus. PowerKaraoke comes with an animated tutorial that shows how to create CD+G song. And the new version with full duets is coming soon.
You may also want to read this discussion.
PostPosted: Thu Nov 24, 2005 6:26 am
I have the same Burner...and i used Clone Cd...i've had NO problems at all with it. works great.
PostPosted: Thu Nov 24, 2005 7:36 am
I got my "extra" plextor drives I ordered... guys, I'm tellin' ya, get some now before they're out of stock (of the ones that work with karaoke subcode) and instead you have to rely on a "program" to do the ripping.
PostPosted: Thu Nov 24, 2005 9:53 am
*perk* extra?!?!?!?!??! hehehee
PostPosted: Thu Nov 24, 2005 12:57 pm
buy yer own dammit! LOL!
Users browsing this forum: No registered users and 2016 guests
