KARAOKE SCENE MAGAZINE ONLINE! - KARAfun naming??????????? Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Fri Oct 23, 2026 11:42 pm
PostPosted: Sat Feb 03, 2018 11:52 am
Been Liked: 50 times
I have a fill in KJ that only knows karafun.
After installing it it will not import my library correctly. How
can I set karafun to read standard filenames Diskid-artist-title?????
cheers
PostPosted: Sat Feb 03, 2018 1:08 pm
Are your MP3 files tagged? That's how I got it to read my library but I have never used it in an actual show. Personally I would insist on teaching him your software. If he's not willing to learn it then I would pass on using him. I really don't consider KaraFun professional Karaoke Hosting software myself.
PostPosted: Sat Feb 03, 2018 2:28 pm
Images: 6
Been Liked: 52 times
Karafun uses ID3 tags to import songs... there is a thing in the REGEDIT you can change but I've tried it and doesn't do anything...
Best solution for your friend is to Import all the songs into KJFILEMANAGER > Select all tracks > WRITE MP3 DATA
keep in mind if you use the search... it will find the song your looking for regardless of the naming.
PostPosted: Sat Feb 03, 2018 3:30 pm
If you have a large library, it takes forever for the list to populate to what the ID Tags read so far that time the list will look out of wack.
PostPosted: Sat Feb 03, 2018 4:15 pm
I totally agree with Danny. You are the employer. You should not have to accommodate your employee. If he wants to work for you, he either learns to run your program or he's out.
PostPosted: Sat Feb 03, 2018 4:41 pm
If the files are zipped Karafun won't be able to read the tag, because the tag is attached to the mp3 file not the zip.
PostPosted: Tue May 22, 2018 4:59 am
Best solution, easy peasy to run and learn. Reads either by formal naming convention or tags. OpenKJ.
PostPosted: Tue May 22, 2018 1:02 pm
THIS!
Users browsing this forum: No registered users and 2449 guests
