KARAOKE SCENE MAGAZINE ONLINE! - 19" rackmount a JVC-22BK Karaoke CDG player Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Wed Nov 04, 2026 10:26 pm
PostPosted: Sat Oct 31, 2009 3:18 am
As title says Im after rackmounting my old player to be able to play customer discs or as a back up if computer fails and i can revert baqck to the discs until sorted.
Plus what would i need to connect it as im using a http://listings.maplin.co.uk/Module.aspx?ModuleNo=35258
to connect from laptop to big screen and it passes through to LCD screen so I can only gather some kind of switch would be needed or is there something I could replace the pc to tv converter for.
Thanks in advance all
PostPosted: Sat Oct 31, 2009 4:35 am
Zonerc,
What software are you using to play your computer files?
If you are using CompuHost, you can go through the PC using a video capture card(which is the opposite of what you just linked to) and control the switch right from Compuhost. the link below is what is suggested by Compuhost for the setup.
http://www.tigerdirect.com/applications ... CatId=1428
PostPosted: Sat Oct 31, 2009 4:49 am
Thanks DannyG2006
But I use Sax and Dotty's latest Show Presenter so dont have that option on that.
PostPosted: Sat Oct 31, 2009 5:16 am
To rack mount your CDG Player, all you need is a shelf like this:
http://accessories.musiciansfriend.com/ ... sku=421306
Just measure the size of your player (vertically) and be sure to get the right size shelf. The one I linked to is a 3-space shelf, you might only need a 2 space shelf. Remember that each rack unit (space) is 1.75 inches.
Then for switching between 2 video sources, I'd recommend a hardware solution. Get a smart switch similar to this one:
http://www.amazon.com/Philips-PH-61153- ... B000165AOY
On there you set one video input as your default source (the PC) and it will automatically stay on that source until another source starts sending a signal (the player). So you'd keep the player turned off except when you need it.
Use two separate channels on your mixer for the audio from those two sources or you could run them through that switch as well.
DJ Tony
PostPosted: Sat Oct 31, 2009 5:30 am
Thanks letitrip
but just tried to find the philips thing but dont see available in the UK
using the wording ,dont find anything in search ,but will keep looking .
Does that shelf clamp the playing so if you tip your rack on its side to get it in the car?
PostPosted: Sat Oct 31, 2009 5:47 am
The shelf he is referring to will hold the player in place. I believe they make ears for that player but I could be wrong.
http://www.karaokedirect.co.uk/ultimate ... -1858.html
okay that link is for a specific player. Here is one for yours:
http://www.karaokewh.com/item_details.c ... raoke.html
PostPosted: Sat Oct 31, 2009 5:57 am
Thats what I thought danny ,sure I had seen some ears somewhere but cant find them anywhere now.
PostPosted: Sat Oct 31, 2009 6:17 am
did some more researching and this UK site has the ears for your player.
http://www.emkaraoke.co.uk/newsite/inde ... lang=en-gb
PostPosted: Sat Oct 31, 2009 9:13 am
Thanks Danny well thats that sorted unless I find cheaper ,just something to use as some form of switch ,was thinking of getting a cheap dvd player as had a few people at parties wanting to play dvds they have made up for who ever the party is for so maybe something that will let 2 players to plug.
Users browsing this forum: No registered users and 1858 guests
