KARAOKE SCENE MAGAZINE ONLINE! - mackie cfx 12 question Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Thu Nov 05, 2026 7:43 am
 Post subject: mackie cfx 12 question
PostPosted: Mon Jun 22, 2009 7:07 pm
I want to use a powered speaker for a singer monitor, I"m using aux1 and 2 for effects, where do I go with the monitor, I want to control the volume, possible to use the headphone out.? or ?
PostPosted: Mon Jun 22, 2009 7:23 pm
Put your FX processors on the EFX send jacks, and then use your monitor on AUX1 or AUX2.
Jeff Wheeler, moonlight DJ/KJ
PostPosted: Mon Jun 22, 2009 7:56 pm
Are you just not using the onboard FX because you don't like them or are you using them in conjunction with additional outboard FX? If it's because you don't like the Onboard FX because you don't like them you can still use the the FX Sends and Returns with your external devices and mute the internals, leaving your Aux's available. If you are already using all of your FX and Aux sends and returns then I think you could use Sub 3/4, Utility Out or Headphone Out to send a signal for a monitor.
PostPosted: Tue Jun 23, 2009 1:40 am
You want to use the actual AUX sends for the monitors. The EFX sends are what you want for the effects. If you want to use just outboard effects, then put them in EFX send 1. For the return I prefer to use an open channel instead of the effects return. In this way you can actually use both the internal & external in conjunction with each other to make a nce layered effect. Just make sure to never 'send' the external effect it's own send!
Users browsing this forum: No registered users and 1891 guests
