KARAOKE SCENE MAGAZINE ONLINE! - setup Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Thu Nov 05, 2026 10:10 am
 Post subject: setup
PostPosted: Sat Apr 04, 2009 9:52 am
It seems our last 2 setups work better with the speakers on the opposite end facing the singers. We dont run a stage monitor and never have any complaints about I cant hear me. They hear all the efx and all seem to prefer that way.
Whadda think?
This a layout and photo.
layout
room
 Post subject: Re: setup
PostPosted: Sat Apr 04, 2009 12:16 pm
I guess this can work in a small hall with a relaxed and quiet atmosphere. I would not do that in a larger venue with 100+ customers. Also keep in mind that the way ear/brain audio processing works, the direction a sound is coming from has a lot to do with the listening experience, hence the advent of stereo, surround sound, blablah vs the old school metal speakers at the drive-in movies :)
My console-format mixer has on-board FX that can send to AUX1/2 (my monitor mixes) and I experimented with sending some FX into the monitor mix. I think it is okay for karaoke singers in moderation, but if you send so much that they don't hear their voice clearly, their singing will suffer. Professional singers would have a fit about a bunch of reverb on their IEM/wedges. Shy / amateur singers, on the other hand, seem to take comfort in the vocal FX. Also, delay on monitors can be really distracting, as can similar effects like side-chain gated/expanded reverb.
If you want FX on your monitor mix but your mixer doesn't have built-in sends for it, check and see if it has an FX output that you can route into an unused channel strip. Then you can route the FX signal to anywhere you want. Just don't route the FX signal back into the FX processor a second time!
Jeff Wheeler, moonlight DJ/KJ
PostPosted: Sat Apr 04, 2009 12:47 pm
Been Liked: 31 times
That may work in that room where you are actually able face the speakers with enough seperation to face each other like that.
In all my venues my KJ/ singer area is behind the mains, so I have a THIRD speaker that both faces out but toward the singer. This is not my choice, but the set up is a result of the shape of the room versus where I'm forced to set up. Most bars were not designed with karaoke in mind. lol
That said, it sounds pretty good. All I've done for the monitor is to cut the base and highs, but turn up the mids and I'm running it daisy chained off one of the mains. Quirky, but it works... and I can get an accurate picture of the mix too.
Walking from the booth to the room is interesting. There's this "sound curtain" where i move from hearing the stage to room sound. Its mostly the same only with a fuller richer overall sound.... but the singer/music mix is almost the same.
Pretty interesting how that works.
Users browsing this forum: No registered users and 2345 guests
