KARAOKE SCENE MAGAZINE ONLINE! - Internet and computer optimization programs Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Fri Nov 06, 2026 10:43 am
PostPosted: Mon Mar 16, 2009 10:14 am
Hi,
I'm finding some problems with my PC running a bit sluggishly. There are loads of programs advertised that claim to make big improvements.
Anybody tried them? And are there a few that appear genuine, and, at least, won't do any harm?
Ian
PostPosted: Mon Mar 16, 2009 4:46 pm
hotglove @ Mon Mar 16, 2009 1:14 pm wrote:
Hi,
I doubt there are any that are good in that regard.
Most systems that run slow have a configuration problem. Either too much software runs on startup -- disable it all or remove programs you don't need. Or the one that I see cause the most grief -- scheduled anti-virus runs that begin as you come out of hibernation. The cure for that is to do a weekly run manually, and turn off the auto-scheduling.:w
PostPosted: Mon Mar 16, 2009 9:36 pm
For XP go here register and do these tuning tips.
xp
Here is another handytool
One of the best coMputer forums I have used for years is amazingtechs
PostPosted: Tue Mar 17, 2009 4:40 am
Personally - I distrust any of these "wizard based" apps to keep a computer supposedly "healthy".
My karaoke laptop has the apps on it that it needs. I do not put anything on it that's not been tested elsewhere. Moreover, it NEVER see's the Internet.
THAT is how I keep a computer clean.
Now, assuming damage has already been done to your install... Run a GOOD virus scanner, run a GOOD malware scanner. Delete temporary files (use the disk cleanup). Defrag (for what it's worth). Use MSCONFIG to stop unneeded apps at startup...
PostPosted: Tue Mar 17, 2009 7:14 am
Thanks, I use the machine to stream Karaoke from Sing To The World, and upload to Singers Showcase, so Internet connection is necessary, but I will check out the links suggested, and continue to try and keep it running "lean and mean"
Thank you for your help.
Ian
PostPosted: Tue Mar 17, 2009 7:38 am
You run your show entirely streamed? Wow!
OK, ensure you have good protection on that :)
PostPosted: Tue Mar 17, 2009 7:47 am
Been Liked: 34 times
Hi,
Ian
Of course you can use software that will improve...
First, you should run this software on a regular based:
http://www.ccleaner.com/
Secondly, you should defrag your drive on a regular based:
http://www.defraggler.com/
And finally, remove those Spyware:
http://www.superantispyware.com/?tag=GO ... NTISPYWARE
All of the above programs are FREE :wink:
And most important, you SHOULD use Firefox along with some add on and NOT IE when surfing the net, THAT will help keep your system clean and safe :wink:
Users browsing this forum: No registered users and 3092 guests
