Posted: Thu Jan 08, 2009 12:53 pm |
Micky @ Thu Jan 08, 2009 1:44 pm wrote: Lonman @ Thu Jan 08, 2009 3:33 pm wrote: jamkaraoke @ Thu Jan 08, 2009 1:22 pm wrote: You guys should contact LATSHAW ...usually they are pretty good at responding I'm using VISTA and it works ...(knock on wood ) I'm not too worried about it. The way I see it if a demo can't work properly, then it isn't worth buying IMO. It may be the best program out there, but it didn't work on my machine. I am content with my current software. Does exactly what I need it to do - play karaoke music. Good point but keep in mind that a software might not work perfectly all the time, it might sometime run in conflict with you Bios, drivers... About the software you're using, it would be my first pick if only it was built on Bass  But that will never happen
Oh I understand that. But if I have to go deep into BIOS or something else just to get a demo to work, i'd rather not deal with it. Simplicity is a good thing sometimes.
As far as the sound of my current software, i'm very happy with it. It's going through a very nice sound card & through a nice PA. In a side by side with that actual disc, the software actually seems to sound a little better - could be due to the sound card properties.
ggardein
Posted: Sun Jan 11, 2009 1:19 pm |
| Advanced Poster |
Joined: Thu Mar 22, 2007 6:12 pm Posts: 339 Location: D.C. Been Liked: 3 times
I loaded the demo on an older computer, and it worked, but I shut it down after a minute or so, because the program made my CPU go from 0 to 100%....  ...it only uses 20% or so on my newer computer. Several things affect what your CPU can handle, processor speed, bus, motherboard, OS, ram...I'm sure I left things out, and maybe included something that doesn't....  ...but both computers have 1G of ram, but the older one has an AMD Sempron at 1.8GHZ, OS- WinXP, and the newer one has an AMD Athlon 64 X 2 dual core at over 2GHZ, OS -WinVista(I know 1G of ram is low for Vista...  )......program is definetly a bit too hungery for an older machine...  ....rather than adding more ram to the older machine, not that it would even help that much, I'll just use older kj programs on it.
Posted: Sun Jan 11, 2009 1:29 pm |
nobodyhome @ Sun Jan 11, 2009 2:19 pm wrote: I loaded the demo on an older computer, and it worked, but I shut it down after a minute or so, because the program made my CPU go from 0 to 100%....  ...it only uses 20% or so on my newer computer. Several things affect what your CPU can handle, processor speed, bus, motherboard, OS, ram...I'm sure I left things out, and maybe included something that doesn't....  ...but both computers have 1G of ram, but the older one has an AMD Sempron at 1.8GHZ, OS- WinXP, and the newer one has an AMD Athlon 64 X 2 dual core at over 2GHZ, OS -WinVista(I know 1G of ram is low for Vista...  )......program is definetly a bit too hungery for an older machine...  ....rather than adding more ram to the older machine, not that it would even help that much, I'll just use older kj programs on it.
Yeah mine was on a AMD Athlon 2.8ghz dual core processor, 2gb ram, Vista (which is probably what killed it  ).
ggardein
Posted: Sun Jan 11, 2009 1:53 pm |
| Advanced Poster |
Actually the vista is the one that worked for me....  .....I'm lost....maybe the download developed a corrupt file/files somehow.....
Micky
Posted: Sun Jan 11, 2009 1:55 pm |
nobodyhome @ Sun Jan 11, 2009 4:19 pm wrote: I loaded the demo on an older computer, and it worked, but I shut it down after a minute or so, because the program made my CPU go from 0 to 100%....  ...it only uses 20% or so on my newer computer. Several things affect what your CPU can handle, processor speed, bus, motherboard, OS, ram...I'm sure I left things out, and maybe included something that doesn't....  ...but both computers have 1G of ram, but the older one has an AMD Sempron at 1.8GHZ, OS- WinXP, and the newer one has an AMD Athlon 64 X 2 dual core at over 2GHZ, OS -WinVista(I know 1G of ram is low for Vista...  )......program is definetly a bit too hungery for an older machine...  ....rather than adding more ram to the older machine, not that it would even help that much, I'll just use older kj programs on it.
You should have activated the "Cpu Saver" option, that's why it's there, for older machines
Posted: Sun Jan 11, 2009 1:56 pm |
nobodyhome @ Sun Jan 11, 2009 2:53 pm wrote: Actually the vista is the one that worked for me....  .....I'm lost....maybe the download developed a corrupt file/files somehow.....
No I downloaded 3 times thinking the same thing. I'm on high speed broadband - not like a dial up glitch or something either. I don't know, like said, i'm not worried about it though. Gave it a shot, didn't work, not going to lose sleep trying to trouble shoot it.
DannyG2006
Posted: Sun Jan 11, 2009 6:29 pm |
nobodyhome @ Wed Jan 07, 2009 6:20 pm wrote: Anyone know how many licenses you get with it?
also, why won't it work with your computer, Danny?
It won't even open up just gives an error message saying somthing didn't work right.
ggardein
Posted: Mon Jan 12, 2009 10:08 am |
| Advanced Poster |
You should have activated the "Cpu Saver" option, that's why it's there, for older machines  [/quote]
Thanks for the suggestion Micky.......I've tried checking both boxes, but I'm still at 100%....  ...might have actually been above that without saver.....it actually works well, but I don't think it's a good idea to run it too long at 100%.....I'm still just playing with it for now. I'm one of those guys that put things together without reading the instructions first.......  ....then when I get in trouble, I go back and start reading them......and as always, thank you, and everyone on this site for always being so helpful.....Greg
knightshow
Posted: Mon Jan 12, 2009 11:18 am |
is there a check option box to close if the download is done?
Users browsing this forum: No registered users and 1693 guests |
