mrdelicious2
Posted: Wed Dec 17, 2008 7:03 am |
Joined: Tue Oct 03, 2006 8:28 am Posts: 522 Location: Michigan, USA Been Liked: 0 time
Thanks for the help guys. It seems that there is 'pain' involved here with what works and what doesn't. I want to buy the right equipment, no adapters if possible..sometimes is seems I keep throwing good money after bad and I can't seem to catch up. I will try one or both of these options (cable/adapter) and get back to you with the results or successes! MrD
_________________ [highlight=midnightblue]MrD - KJ/DJ Specialist Visit MrD on facebook - mrdsentertainment & on myspace - larrynance[/highlight]
knightshow
Posted: Wed Dec 17, 2008 8:51 am |
st1rin2gs
Posted: Wed Dec 24, 2008 1:17 pm |
Joined: Mon Dec 08, 2008 6:55 pm Posts: 12 Been Liked: 0 time
As an update: I ordered the UCA 202 from Sweetwater and installed it and it works fine. It turns out that Compuhost will work with any external usb card that uses the windows usb audio codec. Digidesign uses their own driver so it is not supported.
mrdelicious2
Posted: Mon Dec 29, 2008 7:43 am |
Update:
Cheap - S-video to Rca (adapter) cable........solved the problem. The connection is crystal clear and doesn't get lost upon switch to another input!
Thanks, Matt!!!!!!!!
MrD
Posted: Mon Dec 29, 2008 7:46 am |
mrdelicious2 @ Mon Dec 29, 2008 10:43 am wrote: Update:
MrD
I wonder why mine always lose color when I connect them? How long a cable are you using?
knightshow
Posted: Mon Dec 29, 2008 10:09 am |
The one I sent MrDelicious was a $0.57 discontinued adaptor that used to be given away with video cards a while back.
I did it to prove a point. I've been using these suckers for three years, and never ONCE had a problem.
That site I had linked earlier ( http://www.svideo-rca.com/ ) has similar adaptors, as does Pccables.com... Svideo-rca.com mentions some adaptors that give out the black and white fuzzy pictures... I think they are ill-made ones that don't connect up a couple of the four pins that carry the s-video signal.
Posted: Mon Dec 29, 2008 5:38 pm |
knightshow @ Mon Dec 29, 2008 1:09 pm wrote: The one I sent MrDelicious was a $0.57 discontinued adaptor that used to be given away with video cards a while back. I did it to prove a point. I've been using these suckers for three years, and never ONCE had a problem. That site I had linked earlier ( http://www.svideo-rca.com/ ) has similar adaptors, as does Pccables.com... Svideo-rca.com mentions some adaptors that give out the black and white fuzzy pictures... I think they are ill-made ones that don't connect up a couple of the four pins that carry the s-video signal.
Can you ring it out so I can get a pinout? There are only two pins on an RCA, of course, so it may be that you can solder a jumper.
It would be nice to have this in the forum's memory so we can help people determine which are the right cable adapter. I have three of them that don't work in color, from three different places....
knightshow
Posted: Mon Dec 29, 2008 7:38 pm |
beats the heck outta me... seems reasonable, though.
I'm wondering... which three cables you have?
I have ONE more of the adaptors. PM me your address, and I'll send it to you!
Posted: Mon Dec 29, 2008 8:27 pm |
knightshow @ Mon Dec 29, 2008 10:38 pm wrote: beats the heck outta me... seems reasonable, though.
Done! I will make a schematic and tell people how to wire a cable. I will also tell LondonLive and Ollie so they can digest it and make suggestions.
Users browsing this forum: No registered users and 2563 guests |
