KARAOKE SCENE MAGAZINE ONLINE! - Echo not work Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Fri Nov 06, 2026 12:16 am
 Post subject: Echo not work
PostPosted: Mon Oct 20, 2008 8:06 pm
I have a KJ-7808RV Karaoke Mixer. The DSP Vocal Echo with Level, Repeat and Delay controls function can not work most time. Something when I trun on it works, if I turn it of then on again, it does work. Does someone know what's wrong with that? Thanks!
 Post subject: Re: Echo not work
PostPosted: Tue Oct 21, 2008 3:02 pm
Hi:
I have the KJ7800-PRO Mixer. If you are not getting any vocal effects, ensure the echo button is pressed down. This button is under the right side of the equalizer, and just under the Cue/live button for the headphones. Right side of mixer, just left of master echo level knob.
After you verify that the echo button is depressed, ensure you are giving any effects on the master controls. Try these settings on the echo, turn the master, the delay, and the repeat knobs all to one click past center. Now make sure the mic you are singing on has it's echo control set to about 1/4 of max level.
I use these settings and get great vocals with my UHF-5800 microphones.
If you have any questions let me know, I know this mixer well.
Felix the KJ
8)
PostPosted: Tue Oct 21, 2008 3:55 pm
My mixer is KJ-7808RV. There is no echo button. After "long time"( > 10 mins), the echo functio works well. After i cycle the power switch, the echo function gone. I should wait another "long time" to get the echo function. If lucky, the function maybe work normal after next power cycle. I don't know why.
Users browsing this forum: No registered users and 2108 guests
