KARAOKE SCENE MAGAZINE ONLINE! - quick techy ? Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Thu Nov 05, 2026 2:50 am
 Post subject: quick techy ?
PostPosted: Wed Nov 08, 2006 3:03 pm
Been Liked: 8 times
I have purchased an m-audio fasttrack guitar/mic recording interface
Its not what Keith suggested but its more portable with an xlr connection and has a pre-amp if I ever get round to purchasing a condenser mic. Thing is when recording to Adobe Audition my mic is recording in mono on a stereo track in multitrack. This means I spent bloody ages copying and pasting left to right
Is there a way to get it to record to both left and right? Why is this any different to going thru my mixer? I am using the same mic and cord plugged into the fasttrack so I am confused as to why it will only record on the left
aside from that I am pleased with the clarity and look forward to getting up close and personal with some rockier material
 Post subject: Re: quick techy ?
PostPosted: Wed Nov 08, 2006 7:06 pm
Mic is mono only..... Normally you track into one channel then bounce down into stereo....True stereo is with 2 mics........
PostPosted: Wed Nov 08, 2006 7:19 pm
There must be a setting somewhere in AA that you can change. It seems that you are recording the mono signal onto a stereo track setting. Change the setting to mono and you will get one track at the center.
I don't use AA so I don't know where to look.
PostPosted: Thu Nov 09, 2006 12:29 am
Been Liked: 8 times
why doesnt it do the same when recording thru the mixer then?
PostPosted: Thu Nov 09, 2006 12:34 am
The mixer split the mono signal to left and right. It does not make it stereo; just 2 mono
PostPosted: Thu Nov 09, 2006 1:08 am
Then why have a stereo mixer?
PostPosted: Thu Nov 09, 2006 1:13 am
So you have a choice.
PostPosted: Thu Nov 09, 2006 2:20 am
Been Liked: 8 times
I dont mind that its mono but its left channel feed only so unless I copy and paste to right vocals only come out of the left headphone or left speaker
PostPosted: Thu Nov 09, 2006 10:04 am
When recording your mic, select the AA recording channel to be a mono channel. That way it will record left and right, but identical, a so called split mono signal. That way you don't need to copy/paste. The reason it works with a mixer is the same. It is set up in such a way that it duplicates mono channels to both left and right, otherwise your guitar/mic would always play on one channel only.
PostPosted: Thu Nov 09, 2006 11:12 am
Been Liked: 8 times
ok experimented and managed to do that ok... looks weird but at least its centred I guess I may be on a learning curve that destroys all I believe in re-recording
Thank you Allstar.
Users browsing this forum: No registered users and 2115 guests
