KARAOKE SCENE MAGAZINE ONLINE! - Shure SM86 mic Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Wed Nov 04, 2026 11:56 am
 Post subject: Shure SM86 mic
PostPosted: Fri Jul 07, 2006 10:45 am
I am looking for a few relatively inexpensive ways to upgrade my sound quality.
Right now I run the following equipment:
Yamaha S115V mains powered by a Yamaha P5000S amp
Yamaha BR12 monitor powered by a Samson Servo 300 amp
Yamaha MG16/6FX mixer
BBE 362 Sonic Maximizer
Numark CDN25G CDG Player
Shure 58SM Mics
My first purchase is going to be to upgrade to Speakon Connectors, which I have been told make a discernable difference for a small investment.
Does anyone have any experience with the Shure SM86 mics? They advertise to have the quality of condensor mics but feedback and background noise control of performance mics.
Also, does anyone else have any suggestions to help my sound? I just blew my subwoofer and may be upgrading that with my next major purchase, but for now I am focusing on the little things...
 Post subject: Re: Shure SM86 mic
PostPosted: Fri Jul 07, 2006 11:16 am
I would prefer the sm-57 mics to the sm-86. Better and more controlable sound. You already have a pretty decent system.
now, for a subwoofer, I would suggest a 10" deep throw bandpass box like they use in car stereos. I have a peavey pv-118 and one of the band pass boxes. I swear the 10" bandpass has more bass than the 18" does. and I am feeding them both with 1300 watts per speaker, so I consider this a good example. it is also about half the price of the 18" Especially if you get the 10" deep throw at circuit city. They will give you a lifetime replacement on the speaker.
PostPosted: Fri Jul 07, 2006 11:32 am
I actually have a dual 12" deep throw bandpass box that I won in a karaoke contest. How in the world do you SAFELY hook a car stereo component up to a PA system??
Maybe run the REC OUT RCA jacks from my mixer into a home theater receiver and connect the box to the main outputs of the receiver. Is that safe though??
PostPosted: Fri Jul 07, 2006 1:06 pm
TopherM @ Fri Jul 07, 2006 11:32 am wrote:
I actually have a dual 12" deep throw bandpass box that I won in a karaoke contest. How in the world do you hook a car stereo component up to a PA system, though??
You would hook it up as any speaker in a PA - the speaker cord would need to be configured to plug into the speaker jack or rewire the box to use 1/4" or Speakon connections.  Although these types of speakers really aren't designed for for the riggers of PA use & make sure you have an external crossover and an amp properly rated for the Program power rating of the sub.  Bandpass boses are VERY limited in the frequencies they project, they were basically designed to give more bass out of lower quality speakers, these boxes generally are bigger & don't have a long throw.  Yes they can create more sloppy bass (found in many vehicles for the boom boom) & sound loud but if the subs start distorting, you may not even hear it, but the projection will not be there & and again, very limited on the frequenies it passes - hence "band pass".  Also if the box isn't properly tuned to begin with, you are getting the full benefit from one.
As far as subs go however, with your Yamahas, I would go with the Club series 18" (generally only need 1 on most venues) http://www.americanmusical.com/Item--i- ... --d-2.html and an amp bridged http://www.americanmusical.com/Item--i- ... --d-2.html with an external crossover such as the dbx 223 http://www.americanmusical.com/item--i- ... 7_384.html.  The sub & amp listed would be perfect power rating, already matches the rest of your system & if you wanted to add 2 subs, both subs would be ran bridged into 4 ohms - still a perfect match for the amps bridged rating.
Speakon connectors can make a slight difference in sound provided your amp has Speakon outputs as well, if not it's kind of defeating the purpose for sound quality - however Speakon connectors are nice because they are a locking connection - no kicking the wire out of the speaker if someone accidently stumbles or steps/trips on the cord.  Speakon connectors can handle nearly 10X the amplifier power over standard 1/4" connectors without any major signal loss.  You can actually custom wire a speaker so you can bi-tri amp a speaker using 1 properly configured cable - in typical bi or more set-ups you'd need 2 or more wires running to each speaker.  Most speakon wires are set up for standard use.
As far as mics, the SM86 is a great mic, that's up to you if you want to switch to a more expensive mic, it may make a slight crisper difference in sound that some of the drinkers may or may not notice.  I would honestly stay with the SM58's for now & add the subs & crossovers first - this will take some of the bass out of the main speakers making the vocals stand out a little more crisp.
PostPosted: Fri Jul 07, 2006 8:25 pm
The posts that Jian just added about amps and speaker power, suggests never to use car speakers for a PA system.  They are two differnt animals.   Your car is nowhere near the size of a bar.    :)
PostPosted: Fri Jul 07, 2006 8:35 pm
The two do not mix, but if you know what you are doing, yes.
Users browsing this forum: No registered users and 2360 guests
